Results 1 to 15 of 15
Thread: First Time Wiring Under Gas Tank
    Active Member tlwaggie's Avatar
    Jun 2008
    Colorado
    Default First Time Wiring Under Gas Tank
    HELP! I'm trying my first wiring job and wanted to find out step by step the easiest way of installing wiring from battery compartment to underneath gas tank to tachometer area.
    Thanks guys!
  2. #2
    MoCo Maryland
    Take off the tank and run the wiring up the frame to where you need to run it. make a disconnect in the speedo area so when you take the tank off from now on you can simply unplug your connection
    How I did for my air ride switches
    All I have to do is slide the tank back, unplug the connections and off it comes.
  3. #3
    Very Active Member BigpapaM109's Avatar
    Oct 2010
    Germantown, MD
    Quote Originally Posted by tlwaggie View Post
    Thanks guys!
    Also what exactly are you wiring. It is guaranteed that anything you are trying has already been done. So, with a complete idea of what it is, you will get much better advice and tips to help out
  4. #4
    Active Member
    May 2009
    Narrabeen, NSW, Australia
    Default under tank wiring
    Thanks guys!
    Hi
    For my TRE gear indicator install I loosened and propped the back of the tank and pulled the (single) cable through with a piece of fencing wire (on the clutch side) - I was surprised how easy it was. Form the end of the wire into a tear-drop loop and wrap with duct-tape for both the push and pull directions. It took me about 10 mins and surprisingly no snags
    I still haven't removed the tank completely and probably won't until I really have to!
    Cheers
  5. #5
    Rockdale, Texas
    Don't be afraid to pull the tank if you need to. It's ridiculously easy. One bolt. One quick connect fuel line and 2 plugs and off it comes.
  6. #6
    Active Member
    May 2009
    Cool
    Quote Originally Posted by antmor69 View Post
    Hi Antmor
    Thanks for the encouragement re the tank removal - I'll bear that in mind
    I couldn't help noticing our respective "post" stats - you're at 4k+ since 2010, I'm at a miserable 42 since 2009 - how do you do 4000+ posts in 3 years? Thats over 100 per week - is that even possible? :-)
    Cheers
  7. #7
    MoCo Maryland
    Quote Originally Posted by MrT View Post
    Hi Antmor
    Cheers
    Maybe he has a lot to say!
  8. #8
    Rockdale, Texas
    Hi Antmor
    Cheers
    I'm sure some would say I spend too much time here but I enjoy the brotherhood we all share. And I love learning about my bike and sharing what I know about it. I've got a lot of friends here!
  9. #9
    Active Member
    May 2009
    Hi
    It wasn't meant as a criticism - I enjoy it too even at this distance - also pls pardon the inadvertant and gross exaggeration! :-)
  10. #10
    Rockdale, Texas
    Hi
    It's all good bro! If you look around a little there's a good handfull of guys that post more than me. LOL
  11. #11
    MoCo Maryland
    Hi
    LOL I'm surprised you didn't make your comment towards me. I have the same basic join date and almost twice his post count!
  12. #12
    Apr 2006
    Annapolis, Md
    Hi
    Cheers
    I think it is a good idea to pull it so you can secure the wire/wires to the frame so they don't cause a problem.
    2013 Mid Atlantic Meet CLICK HERE
  13. #13
    Jun 2009
    Fresno Ca.
    Big B likes to get in the mix all the time ,which is fun for me to read!
  14. #14
    MoCo Maryland
    Quote Originally Posted by racer 50 View Post
    Gotta keep it interesting!
  15. #15
    Active Member
    May 2009
    Hi BB
    You didn't reply to my note so your post stat wasn't in front of me - but in any case my observation was more about the disparity between my 40+ and Antmore's 4k+ rather than the figure itself altho it reads the other way
    And agin - no criticism intended - I enjoy it all - keep 'em coming!
    Cheers
