Results 1 to 24 of 24
Thread: Previous Sport Bike Riders
    Active Member bigsexxy's Avatar
    Mar 2012
    Alberta
    Default Previous Sport Bike Riders
    Do you find you drag the hardware almost anywhere on this thing(M109R), even intersections?
    I say this because I was going to hold off on lowering to retain corner clearance etc but man, I find myself grinding pegs way to often at stock height that I might as well lower it if I have to park it in corners to get it to not drag pegs....
    "Live and Learn otherwise the pavement is always happy to deliver another lesson." - Me
  2. #2
    Very Active Member BigBully's Avatar
    Jul 2012
    Woodbridge, Va
    Quote Originally Posted by bigsexxy View Post
    Do you find you drag the hardware almost anywhere on this thing(M109R), even intersections? I say this because I was going to hold off on lowering to retain corner clearance etc but man, I find myself grinding pegs way to often at stock height that I might as well lower it if I have to park it in corners to get it to not drag pegs....
    I thought about lowering as well as big as I am (6'4", 260lbs). Recently coming from a sport bike to this bruiser I still have sport bike turning habits at times. It's strange, I can do a good speed turn with no problem but if I'm making a left turn from a light, I almost scrape pegs every time.
    2011 Black, Cobra PowerPro, Debeavered, DeReflectored, LED Licence plate light, 280 Metzeler Rear/160 Metzeler Front, Legacy Wheels, Sportiva HID Headlight, 2.25 Lowering Bones, Chrome Grill, Chrome Motor Mirror Plates
  3. #3
    Very Active Member windycityrider's Avatar
    Jul 2007
    Chicagoland
    it's just a matter of changing your riding style and getting used to the 109. it is a different style of bike and lots of people tend to forget that it is a cruiser, and although a very powerful one, it does have it's limitations.
    OFTEN IMITATED BUT NEVER DUPLICATED.......THE
    WINDY CITY IS MY PLAYGROUND
  4. #4
    Very Active Member GeorgiaRoller's Avatar
    Nov 2009
    Central Georgia
    Yes...and especially for you coming off of a Sportbike it's gonna be a bit more of a shock to your system. My suggestion is:
    - Don't lower your bike
    - Ride off the saddle in the corners and keep the bike as vertical as you can for more ground clearance.
    But even doing those suggestions your still gonna scrape pegs or the frame of the bike. lol
    Here's one of my oldie but goodie ride videos. Titanium will fly off this bike in the curves. But it's still fun to ride. Just roll with it and enjoy scraping pegs.
  5. #5
    Very Active Member purvistechie's Avatar
    Sep 2007
    Bloomington, MN
    Yes. But it does get better once you figure out the acceptable lean angle. My first corner on the 9 was a peg scraper. I think I'm going to retro fit some titanium feelers on my Dually ISO pegs before I grind them all the way off!
    RED 07, De-beavered, Cycle House Stainless Steel License Plate Bracket, RAW DESIGN Horizontal Chrome LED License Plate Frame, Medium Eagle Eye LED Turn Signals, Suzuki Billit Derby Cover, Suzuki Full Cut Gel Seats, Hard Krome Sideburner Exhaust, Dynojet PCIII Fuel Management, ISO Grips and Throttle Boss.
  6. #6
    Jul 2012
    Woodbridge, Va
    Quote Originally Posted by GeorgiaRoller View Post
    Yes...and especially for you coming off of a Sportbike it's gonna be a bit more of a shock to your system. My suggestion is: - Don't lower your bike - Ride off the saddle in the corners and keep the bike as vertical as you can for more ground clearance. But even doing those suggestions your still gonna scrape pegs or the frame of the bike. lol Here's one of my oldie but goodie ride videos. Titanium will fly off this bike in the curves. But it's still fun to ride. Just roll with it and enjoy scraping pegs.
    When you recorded your videos, did you use a gopro and the suction cup mount?
  7. #7
    kawzx7
    Guest
    I'm ground 1/2" into the pegs. No feelers.
  8. #8
    Nov 2009
    Central Georgia
    Quote Originally Posted by BigBully View Post
    Yes & Yes.
  9. #9
    Jul 2012
    Woodbridge, Va
    Yes & Yes.
    Any fall off issues? I just got one and mounted it right next to the radiator for a quick ride on the fairing and was just a little nervous.
  10. #10
    Very Active Member abejjani's Avatar
    Apr 2012
    northern NY
    Default :-)
    Quote Originally Posted by windycityrider View Post
    so true, after being on a street bike for some time i was scraping pegs left and right ... i totally had to change my riding style and it worked... now with 2inch lower and 40 extra lbs around the beer area :) i hardly ever scrape the pegs ... i miss my ninja every now and then but enjoy every sec of the 9 ...
    "Even though I walk through the valley of the shadow of death, I will fear no evil, for you are with me; your rod and your staff, they comfort me"
  11. #11
    Mar 2012
    Alberta
    I already ride off the saddle and feel funny doing it but I guess it's what needs to happen....
  12. #12
    Nov 2009
    Central Georgia
    Not in almost 3yrs it hasn't. As long as your bike is clean of dirt & your mounting it on any flat surface that mount has the suction cup "lock" and it doesn't go anywhere.
    Nope it's not just you...pretty much everybody scrapes pegs, header pipes, bike frame on this bike in the corners. Just the way that it is.
  13. #13
    Jan 2007
    CT
    Yup coming off a sportbike is a hard transition. There were no chicken strips on my sportbike tires and I drag so hard in the corners I went through the feelers and into the pegs on the 9. I was actually thinking of raising the rear an inch to get better cornering clearance, but I have been after comfort more lately.
  14. #14
    Very Active Member kendall's Avatar
    Jul 2009
    Lincoln Ne
    I would end up dragging my pipes on my 90. I would always get comments on no bitch strips on my tires and wondering how I never low sided it when I would end up out on the shoulder of the tires. Atleast at that point the ground isn't too far away. Nothing like getting a handful of throttle when you are in the apex of a corner and feeling that rearend plant itself
    bikeless at the time
  15. #15
    Very Active Member squirrel's Avatar
    Aug 2006
    Loomis Ca 95650
    Air ride (Arnott) might help it did for me .It gave me about that inch more height that I needed to keep off the pegs so much.Gregg
    I got more in bling than what I paid for It!!
  16. #16
    Active Member
    May 2011
    Willows, CA
    I originally had a sport bike (CBR1000RR) and I've never dragged the pegs on the 9. Here's the thing though. I wear a size 18 shoe and it's also a size or two wider. So, I end up dragging my shoe on the ground instead of the peg.
  17. #17
    Very Active Member lmbull's Avatar
    Apr 2012
    Uhrichsville, Ohio
    It seems like I grind a lot when I make a left hand turn. I rode my cousins ZX6r last week and there is no way I could go back to a crotch rocket.
  18. #18
    Very Active Member BigDave79's Avatar
    Jun 2011
    Western Australia
    i just re-drilled mine and i stick dyna bolts in....they spark like titainium and depending on how long you go for you get heaps of wear and since they are $1 each......who cares
    Those that can't,
    Watch or manage,
    Those that can!
  19. #19
    Very Active Member frankthatsme's Avatar
    Feb 2012
    North Carolina
    Quote Originally Posted by kawzx7 View Post
    Same here! Once I got past a certain point on the pegs it doesnt scrape as often, and like the rider with the size 18 shoes the heals of my boot are my new bank sensors. I purchased a set of stock sensors for my ride to deals gap, came back with out them, decided that I wasn't going to put any more on there.
  20. #20
    kawzx7
    Guest
    Quote Originally Posted by frankthatsme View Post
    Here's a pic of my right shoe after a season.Click image for larger version.
  21. #21
    Active Member weasel848's Avatar
    Jul 2012
    Smithers, British Columbia
    9's can outhandle their clearance all the time. be it off a stop sign, or a buck 20 in a corner. it's just what the beast does. i wouldn't lower mine, maybe air ride for the best of both worlds though.
    E.
    Does this bike make my ass look, small?
  22. #22
    Active Member Jibarito's Avatar
    Aug 2012
    Chicago
    I came off an R1 and I've scraped the pegs a few times. Been concentrating a bit more on my turns but it takes time to change riding styles. At least for me.
  23. #23
    Active Member
    Jul 2012
    Indianapolis
    For those guys that grind pegs or take turns more aggressively, does anyone know how close you are to coming off the tread of the rear tire when the pegs are grinding? I'm just curious because I'm looking to put a 10" wide rear on my bike soon with a 280 tire and I also grind from time to time at stock height and was curious, will I be putting myself at risk of losing the rear end due to the relatively flat nature of the rear tire and the lean angle. Any insight?
  24. #24
    Very Active Member Sciomar's Avatar
    Jun 2011
    WA
    You will have to relearn the lean when you change, same as when lowering, but you'll be in no more danger than you are now IMO. I'm speaking only from watching friends go from the 240 to 280 wider tires, I've only lowered mine and gone to the 250 dunnie for now.
