Results 1 to 15 of 15
Thread: M109R Riding Ergos
    Very Active Member GeorgiaRoller's Avatar
    Nov 2009
    Central Georgia
    Default M109R Riding Ergos
    This is just for fun but it's a pretty cool website to play around with.
    Cycle-Ergo.com
    Click "Add a Motorcycle" and select the Suzuki M109R or any of your other bikes.
    Enter your Height & Inseam.
    You can also customize:
    - Handlebar rise
    - Handlebar pullback
    - Seat rise
    - % of arm straightness
    And it gives you a visual readout of optimal riding position with forward lean & knee angle.
    If you get lower back pain, numb legs or fatigued arms...you might be riding in a jacked up position without knowing it. lol
  2. #2
    Aug 2006
    Interesting, and this chart confirms what I have been thinking. On longer rides my forearms get stiff and I had thought it was because of forward lean. After putting in my measurements, the chart confirmed that I'm leaning 4" forward. It also shows that if I go with a set of +2" risers, my forward lean would be corrected to 0.
  3. #3
    Very Active Member Rambo1985's Avatar
    Jul 2012
    h-town
    I need the +2 risers as well.
  4. #4
    Very Active Member rockey's Avatar
    Jan 2008
    Music City USA
    Quote Originally Posted by Rambo1985 View Post
    Think we all do.
  5. #5
    May 2009
    Vermont
    I'm thinking 5.5" of rise would suit me best. I don't see that
    happening with my current cash flow. LOL
  6. #6
    Aug 2006
  7. #7
    May 2009
    Vermont
    Quote Originally Posted by grampi View Post
    Those look good. Do you know if they increase pullback too? Not sure if
    I want the bars farther back.
  8. #8
    Nov 2009
    Central Georgia
    Those are nice. I think JoDon might have them on his 9. I sat on his once and it was a very noticeable difference with less upper body lean angle with these on.
    Your gonna need to get longer brake & clutch cables as well...right?!
    Quote Originally Posted by xSkyLinedx View Post
    Yes...that's kind of the whole point of getting these...besides the fact that they look nice. They arc your bars closer to you for greater pull back.
  9. #9
    Jan 2008
    Music City USA
    Quote Originally Posted by GeorgiaRoller View Post
    On DLP's site for their 2" risers, they say you can use existing cables.
  10. #10
    Nov 2009
    Central Georgia
    Quote Originally Posted by rockey View Post
    Ok then...that's cool. Might be a bit tight at a full turn...but that would be less work & money switching out the cables. Thanks for the info!
  11. #11
    Nov 2011
    PA
    I got the same risers on the way as well, hoping to cure some of the forward lean. I got a 2011 mdl so I am also hoping it doesnt required new cables and re-routing is all that is needed.
  12. #12
    May 2009
    Vermont
    Do you own them or know some one that has them?
  13. #13
    Jan 2007
    CT
    I don't know how much pull back I would get with a 2" riser. I would need to know that to see how much I would need to correct my 3 degree lean at my height and inseam.
  14. #14
    Very Active Member kendall's Avatar
    Jul 2009
    Lincoln Ne
    104 degree knee angle 1 degree lean on a 109 which isnt too bad
    100 degree knee angle and a 0 degree lean on the 90 i used to own. Should feel very similiar out on the road as far as riding position
    bikeless at the time
  15. #15
    Very Active Member TORQ's Avatar
    May 2008
    SOUTHWESTERN NEW HAMPSHIRE
    There great and there on my bike and many others!
    2" up and 1" back. I'm 6' and NO more lean, arms are straight out! Should have done it years ago.
    I have also heard stock cables will work, have read that for years here on this forum. However I went braided SS on every cable, and went 3" longer on everyone!
    However If I were to do it again!!! My {front brake cables} would have been 2" longer. 3" is a little long, yet again if I let the block just hang it would be better. But I wanted it pinned right where it was.
    TORQ
    Owner of The Rarest M109R, THE 2006 Burple. THE ONE Suzuki Promised, TO NEVER make again!! Do to IT BEING, JUST to FAST for the General PUBLIC!
