Results 1 to 19 of 19
Thread: Overheating issues
    Very Active Member Shibumi's Avatar
    Feb 2010
    Louisville, KY
    Default Overheating issues
    My bike has been overheating for a week now. Replaced the thermostat, radiator cap, flushed the radiator. Still over heating. Fan runs water boils out. Is there any way to see if the pump is working?
    Sent from my SPH-L710 using Tapatalk 2
    渋味 Effortless perfection.
    Wow you're Harley must be really fast, cause you were haulin' azz when i passed you on my M109!
    Very Active Member BAD BOY M109R's Avatar
    Harwood Mo. (SW)
    Take it off check the impeller make sure it is tight and in good shap. Also did you put in coolant and water and are you sure you got all yhe air out?
    BONE STOCK
    Feb 2010
    Louisville, KY
    Yeah I spent close to fifteen min rocking the bike then adding coolant and repeat.
    Can I check the impeller without draining the oil?
    Very Active Member stepink104's Avatar
    Irwin,pa
    Quote Originally Posted by Shibumi View Post
    when you figure it out let us know....mine only does in stuck in traffic..i hate it
    Kenny
    Feb 2010
    Louisville, KY
    Well looking at it I think the oil has to be drained to check the water pump :(
    Feb 2010
    Louisville, KY
    Anyone have an idea for testing the water pump without removing it?
    Feb 2010
    Louisville, KY
    Ok it turned out to be my radiator is plugged. I can't yet any water through it at all.
    Sent from my Galaxy S3 using tapatalk 2
    So are you gonna try to get the stock one boiled out or are you just gonna buy a new one?
    What's it plugged with? How does the coolant look? First time I have heard of someone having this happen
    Very Active Member bwl60's Avatar
    Las Cruces, New Mexico
    I agree! These bikes are really too new to have an issue like that. Unless when the shop put it together, the water they used was crap. I always used distilled water mixed at 50/50 with antifreeze. I also run redline waterwetter. I was having a problem with a quad overheating. The waterwetter put an end to it. Use it in my truck too. When I lived in PHX I learned about it. Summertimes there are harsh!
    Feb 2010
    Louisville, KY
    It looks like it has calcium and lime deposits like stalagtites and stalagtites inside both the top and bottom. This is the problem with being the second owner you never know what the first guy did.
    Feb 2010
    Louisville, KY
    Going to see if a shop here can boil it out tomorrow.
    They should be able to take care of that. That is what happens when tap water is used to mix with the antifreeze. I am the second owner of mine too, I need to check it also. lol
    Quote Originally Posted by bwl60 View Post
    That's why I always use pre-mix coolant. I will use distilled for the flush though.
    Very Active Member fatboy99's Avatar
    Cashville, Tn
    Im with big-b on this. this would be rare and unusual, and you said in beginning you flushed out radiator? make sure coils on rad are not plugged with dust and debris. really sounds more like pumpbut hopefully rad like you're now saying. good luck and get back on road soon.
    Feb 2010
    Louisville, KY
    I took the pump off and inspected it and it's perfectly clean and working fine. I removed the radiator and couldn't get any water through it.
    What do you use and where did you buy it? I think I need to be changing my coolant here pretty soon....it's probably still got the original stuff in it....
    Quote Originally Posted by grampi View Post
    I use Prestone. But w/e you use, make sure it says Silicate free on the container
    I use Maxima Coolanol Anti-Freeze. I know it is more expensive, but I live here in the desert and spend alot of time in Phx too. And I add that Redline WaterWetter. Never had an over heating problem. Stuff works great. And it it protects the freeze side down to -34d, so no worries there either. lol
