Results 1 to 11 of 11
Thread: Ok....next day aired new Gipro/TRE...now need torque spects on oil pan drain nuts???
    Very Active Member Joker's Avatar
    Jan 2007
    Default Ok....next day aired new Gipro/TRE...now need torque spects on oil pan drain nuts???
    Stealer over filled oil upon oil change now oil spewing out of intakes. So i have to drain out some oil and retighten oil plug nuts. What's the torque spec on those nuts? 17lbs?
  2. #2
    May 2009
    Vermont
    snug but not so tight to damage the threads. You don't need
    to torque spec an oil pan plug unless you keep stripping the
    threads.
  3. #3
    Very Active Member lmbull's Avatar
    Apr 2012
    Uhrichsville, Ohio
    Service manual says 16.5 ft lbs.
  4. #4
    Rockdale, Texas
    Quote Originally Posted by lmbull View Post
  5. #5
    Sep 2010
    McPherson, KS
    I would suck it out the top with a livestock syringe. They are cheap ($1) and you can control the amount much better.
  6. #6
    MoCo Maryland
    Not a bad idea! Or one of these
    http://www.harborfreight.com/multi-u...ump-66418.html
    Also not surprised you have stuff for live stock lying around!
  7. #7
    Apr 2012
    Uhrichsville, Ohio
    Totally saw that coming!
  8. #8
    Very Active Member tazman109's Avatar
    May 2011
    Las Vegas
    doh....
  9. #9
    Very Active Member THUNDER217's Avatar
    Jun 2008
    UPPER MARLBORO, MARYLAND
    Default spray bottle
    Or just get a spray bottle and take out the spray part and stick it in and pump the handle and squirt it in what ever you want.
  10. #10
    MoCo Maryland
  11. #11
    Sep 2010
    McPherson, KS
    Here I am, trying to give serious and thoughtful advice (and cheap BTW) and you have to turn it into something dirty because you can't stop thinking about how bad you want to bone some of Harris' private stock. You MD boyz are truly sick.
