Results 1 to 15 of 15
Thread: A new clutch question
    Sep 2011
    Mississauga(Meadowvale)
    Default A new clutch question
    Gentlemen,
    spent a few days parusing the forums and still need help. You see, y'all are talking about fixing what appears to be the inherent clutch problems the 9 came with. My case however involves some poor judgement and an apparent lack of skill. Just before the new 260 went on the back, I set up the cameras and attempted a burn out. It is with great embarrassment that I tell you I was unsuccessful and You Tube viewers will have to settle with "First second third then oops" video for a little while longer. To add insult to injury, my clutch now slips when I shift under HARD acceleration and does it in all gears. At as easy or moderate twist of the wrist, she seems ok (for now). Dealer quoted upwards of 6-7 hundred so I really need to do this on my own. Would greatly appreciate any advise under this particular situation (kit? replace all the plates? simple adjustment?) and will humbly accept the ribbing that comes with a failure of such unmanly proportions as this.
  2. #2
    Very Active Member The Chief's Avatar
    May 2009
    Napa,CA
    Abuse! You play, you pay
    Political correctness is a doctrine, fostered by a delusional illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  3. #3
    May 2006
    How about a link to your YouTube burn-out fail?
  4. #4
    Very Active Member Torn's Avatar
    Jun 2009
    Central VA
    perhaps it looked like this one
    "Motorcyclist are all bound together by a brotherhood tie through their love of the sport, and what difference does it make what make of machine he rides as long as he belongs to the clan" - Walter Davidson 1920.
  5. #5
    May 2006
    Quote Originally Posted by Torn View Post
    Yeah I'm wondering if this is the same person that started the post!
  6. #6
    Sep 2011
    Harsh guys, harsh. And no, my 9 is red.
  7. #7
    MoCo Maryland
    If you don't already have a service manual, it will be helpful.
    http://www.mediafire.com/?m2zniyn4ltj
  8. #8
    Very Active Member devilr1's Avatar
    Jul 2009
    Breslau.On
    That moron in that video, deserves to be shot.
  9. #9
    May 2006
    Quote Originally Posted by cjmac View Post
    Well don't let us scare you away, you knew you were gonna take a few hits for this! Anyway welcome to the site and hopefully we can help you out. By the way there was a reason I asked if you had video, it might help diagnose your problem which I'm sure is just a burnt up clutch.
  10. #10
    Very Active Member stevem109r's Avatar
    Nov 2011
    Australia nsw
    Needs the pin adjusted as per the update. you will find it on the manual link BB posted
    MOTORCYCLE DIVISION 4-STROKEBULLETIN VS/VX/VZ/VL NO. 50
    DATE: 3/8/2007
    SUBJECT: ADDITIONAL SERVICE MANUAL INFORMATION -
    CLUTCH CABLE PLAY ADJUSTMENT PROCEDURE MODIFICATION
    MODEL: VZR1800
    REFERENCE: VZR1800 SERVICE MANUAL (P/N 99500-39291-03E)
    SUBJECT:
    This bulletin is to inform you of a modification to the clutch cable play adjustment procedure.
    Due to the high engine torque and heavy vehicle weight of the VZR1800, correct clutch cable
    play adjustment is important to prevent clutch slippage, particularly under heavy load. Inspect
    and adjust the clutch cable play during pre-delivery inspection and periodic maintenance using
    the following procedure. Insert a copy of each of the attached pages in your dealership's
    VZR1800 Service Manual at the appropriate page.
  11. #11
    Sep 2011
    Thanks guys, will follow up on recent advice stevem. Have the manual already and some previously posted procedures to work with Big-B. Just figured out how to upload 'signature' photo latinrascal...may take a day or two to do the same with my filme-noir of the burn out attempt.
  12. #12
    Sep 2011
    Cool
    test sigpic
    [SIGPIC][SIGPIC]
  13. #13
    Aug 2007
    Montreal subburb
    After you have adjusted everything , if it still slips
    you might want to go in there and see the interns .
    Here is a how-to , well made , step by step
    to take apart and see if all is well .
    http://pagreaves.com/109/clutch/clutch.htm
    While you are in there it would be a great time to mod the push pin
    flat on 2 sides , to never worry about ever getting clutch shudder.
    going all the way on this tutorial
    takes you to the " loosened tubular nut " but from your description
    I think you only smoked some plates ,
    or have the clutch cable too tight , but sounds more like the clutch plates ,
    Every Time You Lift Your Tank Beware Of This .
  14. #14
    Sep 2011
    Thx Kaz
    [SIGPIC][SIGPIC]
  15. #15
    May 2006
    I would recommend what Kazimodo suggested and while your in there take preventive measures to help bullet proof your clutch as much as presently possible by taking it all the way down to the tube nut and redoing it from there to include the new wave washer and seat plate as well as doing the push pin mod. It's only gonna cost you a few bucks more for parts at this point and it seems more likely then not you will experience the clutch shudder if left as is so might as well be proactive with it if you can. I would also highly recommend the factory pro shift star unless you have a newer model(2012 I believe) that already has a similar type already installed
