Results 1 to 7 of 7
Thread: Second Gear
    Jun 2012
    raleigh nc
    Default Second Gear
    Everytime i shift into third gear my bike jumps back to second, and also my left air cleaner keeps leaking oil.
  2. #2
    Jun 2012
    daytona beach,FL
    Thumbs down 2nd gear
    Quote Originally Posted by kdogg7 View Post
    what year is your bike? it does it every time you go into 3rd gear.? what about when you down shift out of other gears what does it do?
  3. #3
    May 2006
    We need more info to help you out! What year, how many miles? Have you missed shifts under power grinding gear dogs?
  4. #4
    Very Active Member Larry L's Avatar
    Mar 2010
    Copperas Cove, Texas
    Someone with more knowledge can probably diagnose 2nd-3rd gear issue.
    The oil problem sounds like a over fill issue. These bikes are very temperamental & if it is slightly overfilled, they will puke oil out of left air cleaner. There are several methods to checking oil. IMHO, the way that works best for me is cold method. You leave bike on side stand over night, before starting bike, you unscrew dip stick & look at it. If there is any oil on it in the normal range, you are good to go.
    Good luck.
    Sent from my super cool iPhone using Tapatalk
    ISO Grips, Breakaway Cruise control, PC-V, K&N Filters, Skythe Mirrors, Gipro ATRE, Cobra Swept exhaust, Sumo-X Side mount, D2Moto tail light with turn signals, Arnott Air Ride.
    Looking to win lottery for more mods.
  5. #5
    Aug 2007
    Montreal subburb
    First to the site .
    shift manly , if the forks are damaged it will not stay in gear .
    your oil leaking is as others have said , to much oil in the bike
    take off the dip stick and suck some oil out with a kitchen tool ,
    if you have stock air filters , you'll have to replace them , they
    cannot be cleaned out , might look into other oil filter brands ,
    some are washable.
    Every Time You Lift Your Tank Beware Of This .
  6. #6
    Jun 2012
    raleigh nc
    Quote Originally Posted by moondoggary View Post
    Its a 08 r2 and yes it does it everytime i go into 3rd gear i have no problems with down shifting.
  7. #7
    Jun 2006
    Greenwood, Indiana
    First, you have a bent shift fork and damaged gears (the gear dogs are rounded off) in the transmission. That really is the only cause of that issue.
    Second, the oiling issue, can easily be caused by overfilling. If you have done an oil change and done it correctly, then you more than likely have to much positive crank case pressure due to unseated rings---not all that uncommon with this issue.
