Results 1 to 6 of 6
Thread: Throttle cables step by step
    Very Active Member PZ's Avatar
    MIAMI, FLORIDA
    Default Throttle cables step by step
    Hey guys, is there any step by step to replace the throttle cables?...pretty sure what to do but rather check first with the Pros...
    Life Is a Beach !!!
    Apr 2011
    Pennsauken, New Jersey
    Yes it's titled exchanging throttle cables with Barnett - listed in the how to. Shows barnett cables but it's the same no matter what kind you have.
    Very Active Member TORQ's Avatar
    SOUTHWESTERN NEW HAMPSHIRE
    Thumbs up Here you go
    http://www.m109riders.com/forums/sho...hrottle+cables
    Rock On Pal But if your going to do this, I would do new grips at the same time! I DID, 1 shot 1 kill!
    TORQ
    Owner of The Rarest M109R, THE 2006 Burple. THE ONE Suzuki Promised, TO NEVER make again!! Do to IT BEING, JUST to FAST for the General PUBLIC!
    MIAMI, FLORIDA
    Thank you very much for your help, it came out great....
    Life Is a Beach !!!
    Hawaii
    I looked at that site but need to get the cable around the plastic insert on the throttle, it to tight. I loosened the cable but cant get on
    Very Active Member CBR1000DUDE's Avatar
    Feb 2007
    Oakley, Ca
    Default Twist it good!
    Quote Originally Posted by Frail View Post
    No, not the dance move. After you get the front cable barrel in it's groove, twist the throttle grip to the 3/4 wide open position and hold it there (or get someone to hold it). Now the rear cable will be long enough to get it into it's place. Easy peasy once you've done it.
    A man has got to know his limitations... Harry Callahan
