Results 1 to 9 of 9
Thread: Passenger pegs relocation kit
    Member mycaljh's Avatar
    Aug 2010
    cleveland
    Default Passenger pegs relocation kit
    Guys I thought I saw somewhere a passenger peg relocation kit,mod,or something
    is their such a thing or am I just hopefull.Her knees get kind of tired after a long ride....NO PUN INTENDED...LOL...any help will be appreciated .
    Michael
    mycaljh@yahoo.com
  2. #2
    Very Active Member lostrider's Avatar
    Apr 2006
    Long Island NY
    Not to much out there other than making your own. But rivco offers a relocation kit but you need to buy their passenger floorboards which you might want to do anyway to make her really happy. Here's a couple of links
    http://www.directlineparts.com/produ...d=9871&str=290
    http://motorcycle-accessories.cruise...tm_source=bing
    You can also try contacting this vendor they might be able to point you in the right direction. A lot of the suzuki's share the same parts so maybe one of these would work.
    http://www.scootworks.com/shop.cgi/p...D=PUT_SID_HERE
  3. #3
    Jan 2009
    Site Co-Sponsor, Zephyrhills, FL
    I swapped the passenger peg brackets from left to right. It pushes the pegs forward about 4 inches. Here's how I did it. I mounted the opposing pegs with the bottom bolts only, leveled the brackets, and drilled a new top mount hole. I also got some cheap universal floorboards so she could move her feet around to adjust her comfort level.
    -Josh
  4. #4
    Very Active Member Luv383's Avatar
    Sep 2010
    Great Bend, KS
    Default Side Covers?
    Josh, does this allow you to use the side covers,or do you remove them when you take your wife with you, and then put them back on later? I had thought of doing what you mentioned, but couldn't figure out the side covers without some cutting.
  5. #5
    Jan 2009
    Quote Originally Posted by Luv383 View Post
    Yes, I remove the side covers when the wife rides. When I"m solo, the passenger pegs and brackets are removed, and the side covers go on.
    -Josh
  6. #6
    Very Active Member CDM76's Avatar
    Jul 2011
    Grande Prairie, Alberta
    mycaljh,
    I did a similar mod to Josh, with no drilling. My gf is 5'10" and has similar problems with the pegs being too close/high for her. I popped the side covers off and switched the passenger pegs to the other side. The link I got most info from was :
    http://www.m109riders.com/forums/sho...passenger+pegs
    I did not drill anything, just switched sides the pegs are on. This effectively moved the pegs forward about 4 inches and down about 1/2 inch. My gf LOVES this set up and is now able to ride for a couple hours without complaints (although she still likes taking a break every hour or two "just because" ) I keep the bike with the 2 vertical side covers off, but all other covers remain on.
    Hope this helped.
    Craig
    Sent from my BlackBerry PlayBook.
    ______________________
    And the modding begins ....... Will it EVER end ?
  7. #7
    Jul 2011
    For anyone still looking for a relocation kit check this out ... http://www.canadasmotorcycle.ca/cobr...n-bracket.html
    I'm going to order one and install this winter. Hopefully I can then put all the covers back on and keep a cleaner look.
  8. #8
    Very Active Member Wjduke's Avatar
    May 2012
    Fall River, Mass.
    My passenger relocation is to the couch....that's where they can stay while I ride!
    2011, Candy Indy Blue. I call her Cinderella...in the beginning, I had to be in before sunset. Not falling totally for the mod trap, just minor looks. She's plenty of bike, and I like it the way it is. I'll hit 13,000 after MAM, and working on a lot more.
  9. #9
    Very Active Member Chops's Avatar
    May 2011
    Oz
    Quote Originally Posted by CDM76 View Post
    Is there something I'm not seeing or do these only suit HD
