Results 1 to 3 of 3
Thread: Clutch Shudder
    Member ian109's Avatar
    Darwin, Northern Territory, Australia
    Default Clutch Shudder
    Guys, this has probably been discussed before but has/is anyone suffering clutch shudder and if so what is recomended in the way of fixes and are the EVO Shift iits that good?
    I have the C109.
    Cheers.
    Ian
    Very Active Member bwl60's Avatar
    Las Cruces, New Mexico
    Default Parts
    I have the M and I think the clutches are the same. First, the Evo shift star is great. Makes it shift faster and firmer. On the shudder what I did was replaced the Washer, clutch plate (wave spring) PN 21472-48G10. Seat,wave washer 21471-48G00. and Plate, clutch Drive No. 2 21441-48G40. And do the pin mod. If you do a search on the push pin mod you will find a picture of the push pin with 3 sides ground flat. But very small like 1/16in wide the length of it. Some say only the push pin mod. On the parts list like on Babbit's, these parts are 12, 13, and 6. And the name I have here are the names on the part diagrams.
    Very Active Member Gold5th's Avatar
    Dec 2010
    Athabasca, AB, Canada
    I have clutch shudder, the star shift does nothing to help it as it happens when in gear. I need to get some more tool to take my exhaust off to take the cover off to deal with it. The pin mod is very tempting.. But I've ordered the new wave washer and a couple other bits, I'd have to go down town to get the parts list.
