Results 1 to 12 of 12
Thread: came home on a flatbed ...
    Very Active Member v8killer's Avatar
    Jun 2011
    On Earth near Seattle
    Default came home on a flatbed ...
    son of a bitch ...
    went to alki beach, had a cup of coffee and bike would not start. 4 hours later (Thanks Ken for riding out and taking a look) i came home on a flatbed now i gotta figure out wtf is wrong and fix it ...
    upside = met some really cool bikers who went above and beyond to help, all stuck around until we loaded the bike and took off.
    i posted a thread under the shop talk section but i'll copy and paste it here too:
    ok so the info first:
    2007 m109 with 4800 miles
    fuses are good
    bike is in neutral
    kill switch to on
    turn the key, lights come on everything looks good to go
    pull the clutch in, fuel pump does not prime.
    cranks over but won't start.
    only mod is an ATRE. no fuel management or anything of that sort.
    took the battery cable off and reconnected to reset the ecu but did not help.
    now onto what happened:
    I start the bike and go for a 20 mile ride, park and have a cup of coffee. about half hour later i get on the bike and the above happened.
    lifted the tank to check for the infamous wire that i've read works it's way out of the connector and everything looks and feels tight.
    when i went to start it it sounded like it started for about half a second and then shut off. it seems like an electrical connection of some sort not sending juice to the fuel pump. or the switch that tells the bike the clutch is pulled in stopped working. or the tip over sensor is bad.
    i guess it's not unheard of for a fuel pump to go bad, but at 4800 miles?
    any suggestions or input is appreciated.
    The uniform does not bring you honor, YOU must bring honor to the uniform. Don't expect blind respect just becasue you wore one.
  2. #2
    Very Active Member kwivrme's Avatar
    Sep 2010
    Cost Texas
    Kickstand up?
    2009 M109R, Dark Cherry Red, Led tail lamps, debeavered,gel seats, custom world backrest,spike grips,and pegs ,Spike bolts and accents by PPM,shaft covers by Cobra,GiPro with ATRE,Arnott air ride,Scythe II mirrors,Gregs caliper and side covers,Immortal Graphix, 300 LED light system by jtsleds.com,160 front 250 rear by Dunlop,Custom short stock pipes,tach relo and more...
  3. #3
    Very Active Member ooinkk's Avatar
    Nov 2007
    Richmond, Va
    Test light the clutch switch , I doubt the pump is bad, but it's possible
  4. #4
    Jul 2007
    Westport Massachusetts
    If you have checked the plug and fuses and all look good and check the wire with a test light I would have to say bad pump. If you tern the key on and you don't hear the pump I would tend to say pump is junk.
    Dave
  5. #5
    Aug 2007
    Montreal subburb
    Brown connector under the tank
    different wire not making contact = different outcome .
    May look good from the outside ,
    undo the connector and see inside for burnt stuff.
    Every Time You Lift Your Tank Beware Of This .
  6. #6
    Very Active Member Todds9's Avatar
    Jul 2009
    Yakima (The Palm Springs of Washington)
    It ran fine until you added the ATRE? Well then, that is a good place to start, remove it and see what happens. Then I would check all the wiring and connections. I actually had installed my ATRE and it is right near the exhaust manifold, well it got hot and burned a wire to ground. Something to think about.
  7. #7
    Jun 2011
    Quote Originally Posted by Todds9 View Post
    ATRE was installed last year but i'll check it for bad connection or burned wire.
  8. #8
    Very Active Member BlessThisNine's Avatar
    Jul 2011
    pittsburgh pa
    Have taken the tank off latley? my bike did the same thong ran it for sometime but then it would randomly shut off then one day it shutofff and wouldnt start...flatbed it home to find out a wire that gies to my fuel pump had pulled loose and lost connection
    Sent from my SCH-I510 using Tapatalk 2
    Stressed?? Have a seat on my office.
  9. #9
    Jun 2011
    Quote Originally Posted by BlessThisNine View Post
    last night was the first time i lifted the tank and that was to check for that very wire.
    looking at the wiring diagram now gonna check the socket for power, if i get power to the socket then the fuel pump is bad.
  10. #10
    Mar 2012
    Tacoma, WA
    Default damn, sorry to hear that
    I was there at Alki too. Just chillin with some friends.
  11. #11
    Jun 2011
    just got done putting her back together and she's singing again, it was the pump. Thanks to Colin for having a spare one around =).
  12. #12
    Very Active Member Fletch 09R's Avatar
    Nov 2006
    Puyallup, Wa
