Results 1 to 21 of 21
Thread: Cleaned up the front with a some freebie
    Very Active Member Tigz's Avatar
    Feb 2009
    Matteson, Il
    Default Cleaned up the front with a some freebie
    Found a couple of cheap LEDs in my tool box, so I put them to good use. The aftermarket stuff are just too expensive for me. This only cost me NADA! Just 1/2hr of my time. I couldn't sleep anyway, hahaha.
  2. #2
    Very Active Member tbar's Avatar
    Dec 2008
    Vine Grove, Kentucky
    Default Good job bro
    And you're most certanily right. The price WAS right.
    "Life's is NOT a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, leaking oil with your engine smoking, shouting GERONIMO!" - Life is tough, it's tougher when you're stupid.- Speeding is ONLY a crime IF you get caught.
    "The Devil Inside" TBAR = That Boy Ain't Right
  3. #3
    May 2011
    San Antonio
    Nice
    The object of war is not to die for your country, but to make the other bastard die for his.
  4. #4
    Very Active Member rockfordrider's Avatar
    Jan 2010
    rockford Il.
    Nice you read my mind< I have been thinking about doing this for a couple of months. could you post up some clear closer pics with out them lighted. It appears that you cut out a slot? how did you attach to the rear of the housing?
    Dave.
    M109-RLE/T
  5. #5
    MoCo Maryland
    Turned out nice!
  6. #6
    Feb 2009
    Matteson, Il
    All I did was drill individual holes for the LEDs. I had a 24 LED strip and cut off 6 from each end, since you can cut the strip every 3 LEDs.
  7. #7
    MoCo Maryland
    Is that what you're using as turn signals?
  8. #8
    Feb 2009
    Matteson, Il
    Yeah.
  9. #9
    MoCo Maryland
    Quote Originally Posted by Tigz View Post
    Yeah.
    Turned out great,
  10. #10
    Feb 2009
    Matteson, Il
    Thank, B
  11. #11
    Jan 2010
    rockford Il.
    Thanks Tigz, so did you flip them on the front and trace the leds? or is there a easier way to get the correct spacing?
    Looks really good. I need to do this to mine.
    M109-RLE/T
  12. #12
    Feb 2009
    Matteson, Il
    Yeah. I taped the front and drew a line for the to make sure it's straight. I put the leds against the tr and dotted along the line. Drilled 7/32 holes and done.
    Don't drill the hole from the back. The chrome will peel off from the front.
  13. #13
    Very Active Member Mrg's Avatar
    Nov 2009
    San Antonio, Tx
    Very clean install!! Let's see them lit up.
  14. #14
    Very Active Member jhardy's Avatar
    Nov 2011
    morehead city and lagrange,nc
    That's awesome looking do you need to do anything to make them two phase meaning will they work as running lights and work as turn signals
    IF IT AIN'T RED........LEAVE IT IN THE SHED
  15. #15
    Apr 2011
    Pennsauken, New Jersey
    I like very clean look
  16. #16
    Feb 2009
    Matteson, Il
    Quote Originally Posted by jhardy View Post
    I'm currently drilling holes along the middle portion of the trim and will be using that as running lights. I tried using LEDs before as run/turn light, and it didn't work too well.
  17. #17
    Active Member lasedrick's Avatar
    Feb 2012
    evergreen al
    What did u use to cover up the hole where factory trun lights go.
  18. #18
    Nov 2011
    OK thanks that's good to know.Please do us all a favor and do a how to that is really a cool idea
  19. #19
    Feb 2012
    evergreen al
    Jan 2010
    rockford Il.
    I used dual intensity moduals on the rear led strips on the bottom of my bags and that works great, but not sure about up front. doesnt the turn signal function in the front just interupt the power going to the bulb? so it would be on all the time and when you put the blinker on the power would be swithed on and off?
    M109-RLE/T
  21. #21
    Very Active Member Rider 4 Life's Avatar
    Nov 2011
    Houston, TX
    You can get them to work as Run/Turn lights, you just need two components: Eclipze2 Module and a M109 Flasher Relay, both from Custom Dynamics.
    I have LED front signals that are also run lights, I used the parts I mentioned above and they work flawless.
    2011 m109R LE, FI2000 AutoTuner, Apus custom mirrors, VStream short shield, Arlen Ness Battistini footpegs and hand grips, debeavered, Raw Design Stealth rear signal lights, Cobra TriPro Black exhaust, Custom bullet LED front signals, Jardine Quick Detach rear backrest, Low and Mean Forcewinder Intakes with screens and daggers.
