Results 1 to 20 of 20
Thread: Don't Make My Mistake.
    Very Active Member M203R's Avatar
    Oct 2010
    Robertsdale, AL
    Default Don't Make My Mistake.
    I learned something in school today and wanted to share it with anyone who doesn't already know:
    Putting Automotive Coolant in your Motorcycle as opposed to Motorcycle Coolant can damage your bike in a way that can make your coolant leak into your oil or visa versa.
    This may be something some people know already. I accept that, however, I want to make sure everyone to knows, because I didn't and I am guilty of doing this out of ignorance.
    If you care, the Silicates in Automotive Coolant can erode the mechanical seal on your water pump, allowing oil or coolant to leak either way.
    This, in most cases as I understand, is not a quick fix as this seal can be deep in your engine.
    Anyone else with more knowledge than me on the matter, please feel free to add info if you so feel the right to.
    Very Active Member freestylejski's Avatar
    May 2007
    Chicago West Burbs
    really?
    I added a cup last season to top it off.
    Am I in trouble?
    Let's Ride!!!!
    That's why you're supposed to use silicate free coolant. Alot of auto manufacturers are using this.
    Very Active Member Captnpirate's Avatar
    Port Saint Lucie, Florida
    I for one did not know this and thanks for letting us know. Keep posting good info like this for us.
    Go Big or Go Home
    '07 RED -
    Cycle House Big Air intakes, Debadged/Debeavered, PC III, Kuy grips and pegs, 50 watt driving lights, 260 Metz., sport windshield, chrome wheels, Gen III Knight Rider, Drivers Backrest, Dragon Tail Light, Derby and Side Lic Frame, +2 risers, 5" Cannon.
    Very Active Member dd's Avatar
    Aug 2010
    Quebec, Canada
    * Use a high quality ethylene glycol base anti-freeze, mixed with distilled water. Do not mix an
    alcohol base anti-freeze and different brands of anti-freeze.
    * Do not put in 60% and more anti-freeze or 50% and less.
    * Do not use a radiator anti-leak additive.
    Denver, CO
    I learned something new today!
    Likely saved me a ton of money! My maintenance contract with the stealer just ran out. Time to start doing maintenance on my own!
    Very Active Member sumo's Avatar
    rhode island
    same goes for oil. car oil is not the same as motorcycle oil
    Very Active Member zzuke10's Avatar
    Kentucky
    RearviewCamera,Flamed Grips&Pegs,Polished Risers w/2in ext.
    Hard Krome Shortened Sideburner,Sumo-X Fat Forktubes, GO-Pro, JSD-3M lowered2.75debeavered,tach relocated,cables relocated grips&throttle bosses RC Polished Component Wheels, Phat front tire170/60/17Phat Rear 280 10 1/2in. rim
    Nov 2011
    Baker FL
    Thumbs up
    Just make sure to read the label...It will say silicate free on the front of the jug. Prestone comes in a blue jug and it is premixed. You will need 2 jugs for the 2.6 gallons and .4 for the reserve tank.
    Hope this helps.
    The long life green coolants are generally all silicate free. Before that, you could only get no silicates with the Dexcool compatible and it had its own issues. Check the back of the container for "silicates" in the ingredients.
    Also, besides the mechanical seal (2 ceramic discs spinning against each other), there is generally at least one rubber seal and maybe 2 between the coolant and the oil. There is also a weep hole to let you know that the mechanical seal is leaking before it gets past the 1st rubber seal and into the bearings. Once it gets there and destroys the bearings, the shaft gets so loose that the second seal fails and then the coolant can get into the oil.
    Very Active Member antmor69's Avatar
    Rockdale, Texas
    Don't freak out. If you use silica free you're fine. Here's what I use.
    Oct 2010
    Robertsdale, AL
    Quote Originally Posted by My1st109 View Post
    Hope this helps.
    Quote Originally Posted by antmor69 View Post
    Quote Originally Posted by TRod View Post
    On my ride home today from school, I thought about this, and looked when I got home, sure enough, there's no Silicates in it.
    Well, at least it doesn't say it has any in it. Only hope they're required to list such a thing...
    Very Active Member g9r's Avatar
    Aug 2011
    Tennessee / North Carolina Mountains
    Good to know. I need to add just a little to my radiator. Didn't have any over the weekend when I had the 9 torn down.
    On a side note, how often should the radiator fluid be changed out on the 9?
    Oct 2010
    Robertsdale, AL
    Just got off the phone with Customer Service for Advanced AutoParts, they confirmed it doesn't have silicates in it.
    Oct 2010
    Robertsdale, AL
    Quote Originally Posted by g9r View Post
    Every 2 Years as per the service manual.
    Very Active Member giovavic68's Avatar
    Aug 2009
    Long Island
    Quote Originally Posted by Captnpirate View Post
    I didn't know either. Thanks for the heads up.
    [DON'T LET A BIG ASS SCARE YA !!!!!]
    "As government expands, liberty contracts." - RONALD REAGON
    Nov 2011
    Baker FL
    Every 2 years for brake fluid too. Replace brake lines every 4 years.
    Hope this helps
    Very Active Member HALO9's Avatar
    long island,ny
    Good looking out bro. Thanks
    FOUNDER, HALO NATION ALLIANCE
    Very Active Member hunt1moore's Avatar
    Monroe, NC
    I use Coolant Boost by Amsoil.
    Active Member zmetal4's Avatar
    Jun 2011
    Reynoldsburg, OH
    good lookin out!
    Shiney Side Up!
