Page 1 of 2 12 LastLast
Results 1 to 30 of 34
Thread: Breakaway cruise control
    Very Active Member MADDMOE's Avatar
    Jun 2010
    MT VERNON, NY ( More than likely im on the bike, i could be anywhere )
    Default Breakaway cruise control
    Thank god for the breakaway cruise control, don't have to worry about hand cramps any longer
    You only live once so , dont talk about it, be about it !
  2. #2
    Very Active Member nukeblade's Avatar
    Aug 2007
    Right on brother! your singing my song
    In truth Victory
  3. #3
    Very Active Member topdog22's Avatar
    Feb 2010
    ELMSFORD, NEW YORK
    Default nice
    it nice to be you
    NY PHATBOYZ ---PRESIDENT---
    HARDY9 THE BEAST
  4. #4
    Jun 2010
    Man Im just trying to be like you a top dog, after the air ride this week I'm done for the mods til winter, I have a few more things to do in the winter
  5. #5
    Very Active Member BAD BOY M109R's Avatar
    Harwood Mo. (SW)
    BONE STOCK
  6. #6
    Very Active Member crossbowme's Avatar
    Mar 2011
    South China, Maine
    I have a new Brakeaway coming - probably be here tonight I think. How big a pain in the a$$ is it to put this thing on. I am an average household mechanic. Change oil, install Gman bushing, minor repairs, that type of thing. After reading some of the comments on here it appears that getting the thing on is NBD but getting it adjusted properly is a big deal. I have a short patience span for some things and am wondering whether I'll have to take it to my local mechanic (he's cool!) to have it put on.
  7. #7
    Very Active Member BigpapaM109's Avatar
    Oct 2010
    Germantown, MD
    Quote Originally Posted by crossbowme View Post
    If you have stock grips, it will be fairly easy. If you have iso grips, use dish soap to get it on and then it will be a slight pain to adjust out.
  8. #8
    Mar 2011
    South China, Maine
    Mine are stock grips - I'll let you know how it goes on my C109RT.
  9. #9
    Oct 2010
    Germantown, MD
    Yea, not sure about the C109 but in general, getting it together and over the bar ends with stock grips is easy as pie. Adjusting it can be a pain but just read the instructions good and you will get it fairly easy. If you get frustrated, walk away and watch some tv and come back.
  10. #10
    Aug 2007
    Exclamation
    Make sure you turn your bars up a little or the Breakaway will ding the tank
    In truth Victory
  11. #11
    Mar 2011
    South China, Maine
    Thanks, I'll do that. I have a bra on but it wouldn't be long before it scratched thru.
  12. #12
    Very Active Member deezilone's Avatar
    Apr 2009
    Westchester, NY
    Moe you say that now but I know you will be buying something before the summer is out...lmao!
    NY Phat Boyz - Vice President
  13. #13
    Jun 2010
    yeah that might be true Dee but i think the only thing im buying now is gas cause it seems like the weather has broken thru & im riding to work again tonight 2 days straight
  14. #14
    Very Active Member KK ENG's Avatar
    Mar 2009
    Auckland New Zealand
    Quote Originally Posted by nukeblade View Post
    I agree
  15. #15
    Mar 2011
    South China, Maine
    Won't be here until Friday. Anxious to get it
  16. #16
    Rockdale, Texas
    Is this with a C or M 109? A friend of mine with an m109 has one and he didn't mention having to adjust his bars.
  17. #17
    Mar 2011
    South China, Maine
    My new Brakeaway works well but it's a lot of adjusting. Half an hour to put it in 1.5 to adjust it.
  18. #18
    Very Active Member Strained's Avatar
    Sep 2009
    Bristol, CT
    One of the best mods for the bike.
    Some rides are sweeter than others, but a 9's not bad.
  19. #19
    Very Active Member mcfling's Avatar
    Sep 2010
    Edmond, Oklahoma
    I added a Throttle Meister. The 109 handle bars are solid, so it had to be drilled out. It looks stock, and works great. I would have my right arm go to sleep- A must mod for me that has worked beautifully.
    Custom painted grey with yellow stripe, engine guards, Longhorn pegs, Kuryakyn floorboards, debadged, debaffled, Throttle Meister, Irate mesh grill, Spudwrench Fairing. Custom made inner fairing with iPhone holder/charger and RockBox radio head unit and built in speakers. Corbin bags, 160 front / 260 rear, Dynabeads, 3" risers with SS 3+ cables, Stebel Horn, HID light. Trackday TRE and Corbin seats with Custom World driver backrest.
  20. #20
    Active Member Papi07M109's Avatar
    Jun 2012
    Alvarado, TX
    Angry Help
    I just got mine today. Im having problems though. its about 1/4 inch too short for reaching my brake lever bolt. I've adjusted everything and finally got it to fit but now its binding. So much so that it won't let the throttle recoil. When I remove it from the brake bolt it moves freely!?!
    Its installed on my 07 M109R over my Kuryakyn grips. Any suggestions??
    I may have to get a longer adjustment screw with a spacer??
  21. #21
    May 2006
    Quote Originally Posted by Papi07M109 View Post
    Sounds like you need to add more spacer in there. The fact that your torqueing the whole setup when tightening the nut/bolt is the problem. Make sure you have the correct spacer size in there and that it is right against the mounting location so that when you tighten the bolt it is not pulling anything together, if that makes sense.
  22. #22
    Jun 2012
    Alvarado, TX
    Thanks. I'm going to the hardware store in the morning. Hopefully that'll fix it.
  23. #23
    Oct 2010
    Germantown, MD
    If you have the brakeaway on and the aluminum block, that is all you need if you are using iso grips and stock levers. You don't need any additional hardware. It is a pain and just takes time. I found that if you leave the small allen screws that lock the brakeaway down to the rubber, loose, it is the best. Leave them loose and then get everything aligned up. If you are off 1/16th of an inche it will bind. if you need to, you can square off the brakeaway to stop it binding and then tighten those screws down and put the cover on.
  24. #24
    Jun 2012
    Alvarado, TX
    Quote Originally Posted by BigpapaM109 View Post
    Oh ok. I'll look at it more in the morning. Thanks again.
  25. #25
    May 2006
    Normaly I would agree with you Big P, that's the way I have mine set but I have been reading a few members on here having this same problem and they state that the spacer provided (aluminium block) was just not wide enough which makes me think that they just didn't have their grip completely seated in which case the easiest fix was to increase the spacer a hair.
  26. #26
    MoCo Maryland
    BP is right. It has to be in perfect parallel or it will bind. They are tedius to adjust and have to be just so to work correctly.
    Then they have something installed/adjusted incorrectly. ISO grips/stock levers, block only. Once I changed the levers to customs, I have to add a shim to the existing block.
  27. #27
    May 2006
    I agree completely with you Big B and I recommend the increase spacer size as a quick fix since they seems to be happy with the way everything else is setup. You can say this is just like the shim you used to get yours right with this setup, sometimes its easier to just add alittle extra!
  28. #28
    Apr 2008
    Mobile Alabama
    I have the breakaway /w iso grips I have had it several years and it's hard to remember the set up but I used what came with the unit with out having to add any thing .
  29. #29
    May 2012
    Central Texas
    Default Like the seat
    Quote Originally Posted by mcfling View Post
    Is that the stock seat and is the sissy bar a quick release?
  30. #30
    May 2012
    Central Texas
    Is that the stock seat and is the sissy bar a quick release? I really need to find a better seat for my 9
