2 inch risers
Results 1 to 11 of 11
Thread: 2 inch risers
    Dec 2006
    Australia,Ocean Shores.
    Default 2 inch risers
    anyone know if you need longer than standard cables if you put 2 inch risers on?
    MoCo Maryland
    Either that or relocate the cables behind the triple tree.
    Very Active Member biscuitpimp's Avatar
    Apr 2009
    soddy daisy, tn
    Quote Originally Posted by scotty109 View Post
    Dang Newbie!
    she s not quite stock.
    Aug 2006
    I was thinking about going with the 2 inchers until I heard about having to mess with the cables. Then I was thinking about going with the 1 inchers so I didn't have to mess with the cables, but now I'm wondering if they make enough of a difference to even bother with them.
    Very Active Member TORQ's Avatar
    May 2008
    SOUTHWESTERN NEW HAMPSHIRE
    I'm headed for 2" longer chrome risers, and i'm replacing all cables. Have been doing it slowly have clutch cable done and push/pulls replaced with new grips. Very easy job! Front brake lines are next! Once thats done i'll be ready for risers. All my cables/lines I went 3" longer and all stainless steel, and they look way better than the black stock ones.
    My opinion is I'm only going to do this Once, and i want to do it right. I know doing it all at once will get pricy so I've been pacing myself if you will! Can't wait really to reduce my forword lean, not that it's much but the thought of setting basicly straight up will be the BALLS as far as comfort. And at the same time will LOOK GREAT!! I've seen the 2" extension pieces but IMO tacky!! {but 2 eachs own.} And they cost around 90 dollars and for another 90 you have full chrome 2" longer risers. Again yea it's more money, but pace yourself you'l be glad in the long run you did. GOD KNOWS I WILL.
    Owner of The Rarest M109R, THE 2006 Burple. THE ONE Suzuki Promised, TO NEVER make again!! Do to IT BEING, JUST to FAST for the General PUBLIC!
    Active Member
    Aug 2010
    Brisbane, Australia
    I rode around for a while just to see if I would get use to the riding position before changing anything. I was getting a little sore at the base of my neck in between my shoulder blades on longer rides. Put 1 inch risers blocks on and have not had a problem since. I too have been thinking about trying 2 inch blocks. Had to cut the bracket under the lower triple tree to give the clutch cable a little mor freedom, otherwise all good.
    Aug 2006
    Quote Originally Posted by woody76 View Post
    You had to cut the bracket for the 1 inchers? Wow! That's one tight clutch cable!
    Active Member
    Aug 2010
    Brisbane, Australia
    Was the quickest and easiest way to free the cable. Have spoken to others that have done the same thing.
    Was only getting tight if going full lock.
    Mar 2007
    West Virginia
    I ran mine with stock cables for a few months, but at full left lock the cables touched the speedometer housing and I didn't care for that. I think you could probably zip tie them out of the way and stop it, but I changed to the longer cables anyway.
    Aug 2006
    Which size risers did you use?
    Mar 2007
    West Virginia
    Quote Originally Posted by grampi View Post
    I have the 2" riser blocks.
