Results 1 to 15 of 15
Thread: De-baffle question.
    Active Member Stevef's Avatar
    Aug 2009
    Perth, Western Australia
    Default De-baffle question.
    Has anybody tried the sending a hole saw down the exhaust on the M90? I see the 109's do it as a way of de-baffling, is our exhaust the same set- up with the baffle lay-out.
    Girpo, Fi2000r, Iso Grips, Magnum mirrors,Tank Guard, Gel Seat, Cobra Luggage Rack, Rear Cowl, Drilled pipes, 2" Bones, De-beavered, Bigeh Air mod and LED's
  2. #2
    Very Active Member Deputy1042's Avatar
    Apr 2009
    West Bend, WI
  3. #3
    May 2010
    Tipp City, Oh
    I dont want to assume I know for sure what the op was asking for.. but I guess I was wondering something similar. For the 109 it looks like you can just send a hole saw down the exhaust pipe and cut out between 1 and 3 baffles..and then drill out the end plate as needed.
    From looking at the post you linked to, it appears much more detailed and complicated on the 90 exhaust.(30 min vs 6 hours)
    Not that its related, but on the Honda Shadow I had I just took a hole saw to the end plate, and the resonator came out, end of story. I had hoped it would be that easy on the 90..looks more complicated..
    I hope I didnt end up hijacking the thread..
    Raw design led signals, Ducks mod, Shayne side mount plate, M109 rear tire,Johnskits 2.5" lowering bones, Corbin seats,cobra slashdowns, PCV with
    autotune, and joe florida accent lights.
  4. #4
    Aug 2009
    I was thinking more like this one
    http://www.m109riders.com/forums/sho...d.php?t=121312
  5. #5
    May 2010
    Tipp City, Oh
    That is what I was thinking as well...
  6. #6
    Apr 2009
    West Bend, WI
    I guess I thought you were looking at actually removing the baffles like Omgrtfa did. I don't see why sending a hole saw down the exhaust wouldn't work with the M90. You could be the first
  7. #7
    Very Active Member amvince's Avatar
    Jun 2009
    Frisco, TX
    Quote Originally Posted by Stevef View Post
    If and when you do it let us know how it turns out. If it fails there is always the 6-8 hour method or aftermarket pipes.
  8. #8
    Very Active Member bpoisson55's Avatar
    Mar 2009
    Maine
    Have you tried just drilling holes in the end plate? 8 half inch holes sounds damn good.
    2011 M109R LE, Iso grips w/ throttle boss, Smoked turn signals, debadged, Jardine quick release sissy bar for the queen. Ride safe!
  9. #9
    Aug 2009
    Yeh but not good enough. The bike definitley needs to breath better bothe in and out.
  10. #10
    Aug 2009
    It's done 7/8 hole saw(with the longest extension you can find over 20 inch) straight down the pipes. One baffle war on top pipe, two on the bottom, sounds great.
  11. #11
    May 2010
    Tipp City, Oh
    Awesome.. I am going to give this a shot tonight..
  12. #12
    Very Active Member 54lariat's Avatar
    Apr 2010
    Justin
    Quote Originally Posted by Kdog90 View Post
    Did u ever try this?
    Google map of us Texas Riders here..https://maps.google.com/maps/ms?msid...af082f63&msa=0
    2009 M90 Lowered,GPS,8k HID,Bars,Chopped front turns, 240 E3, TRE, striped, SS Brake Lines, SideMount LP..... more to come...
  13. #13
    Very Active Member carnivor's Avatar
    Mar 2010
    bendigo,vic.,australia
    Thanks stevef I was hoping that someone would give this a go on the 90 coulld you give us a full run down? eg how long did it take? any probs with the hole saw? has it made it low and rumbly? how loud is it? sorry for the questions but I was kinda of excited and I can't afford to by new pipes.
  14. #14
    Active Member
    Aug 2010
    Savannah, Ga.
    I drilled the 8 1/2" holes about a month ago, Ok sound.
    A week agoI ran a 7/8" hole saw down the middle and took out the little circles, about double the sound of the drilled holes.
    2 days ago I gutted the whole thing. Sound was alot louder and deeper. It was not very loud at running speeds, 45-55-65.
    It was a pain in the A$$ to get both baffles out! I have cut two 3-1/2" circles out of thick screen material and have painted them with high temp paint.
    I will press fit these in the ends of the pipe tonight to cover up the ugliness of gutting the pipes.
  15. #15
    May 2010
    Tipp City, Oh
    Quote Originally Posted by 54lariat View Post
    Kind of.. I had a really hard time finding a 20in extension. I ended up trying it with a shorter extension and taking out one of the baffles on the top exhaust. In the end I am hoping to buy an aftermarket exhaust in the spring.
