Results 1 to 15 of 15
Thread: Handlebars - what is inside?
    Active Member
    Sep 2006
    Default Handlebars - what is inside?
    Hey guys, been awhile since I've been here. The Bike has been stored for quite awhile while I took care of other things. But now I'm getting her back and doing some mods, starting with new mirrors.
    I got a set of Joker Machine Bar End mirrors that look very cool on the bike. These mirrors mount INSIDE the handlebars, requiring removal of the grips for install. Not a problem, grab a set of Kuyrakin Flame grips and do them while I'm at it. So I proceed to pull/cut off the left side grips. When I look inside the handlebar "tube" I see it is not hollow. It looks like there is a piece of aluminum pressed into the bars What is inside our handlebars? How can I get it out?
    I need about 2 inches of depth to mount the mirrors, so I figure I just drill them out as deep as I need them. So after 2 drill bit sets and about 2 hours I drilled the pass side bar end. Got the mirror mounted, new grips on, everything is peachy.
    So I go to the right side bar end and proceed to drill the solid bar end. On my third drill bit (starting very small with a pilot hole, then going up one size at a time up to 3/4") and all the way at the end of the drilling, the bit breaks off!!! The bits are cobalt bits, the hardest I could find anywhere. There is no way I can drill out this bit, it is broken deep inside the bar end, with nothing sticking out to grab on... Here is a pic after trying at it with one of those stepped drill bits, which just hit the broken off cobalt bit and laughed, would not go anywhere deeper :(
    So now I need a new handlebar, and a new set of grips :(
    Anyone know what the hell is inside the bars and how to get it out?
  2. #2
    Very Active Member R1convert's Avatar
    Mar 2008
    Cobourg,Ontario
    Its a steel plug,there's a couple of plug welds on each end holding them in,i ended up drilling and tapping them to mount my bar end mirrors
  3. #3
    Very Active Member T-Bone©®™'s Avatar
    Jan 2007
    Springfield, VA - DC Metro Area
    If ya have to get a new bar, now's the time to upgrade!
    http://www.directlineparts.com/produ...d=2630&str=290
  4. #4
    Active Member
    Sep 2006
    I'm not sure I like the tubular risers, though. I like to the see the machined risers much more now with the tach relocation mod
    I wonder if there are any M109Rs out there with different handlebars, not necessarily the tubular ones.
    Anyhow, it looks like I'm gonna have to get a new set of bars, regardless :(
  5. #5
    Active Member
    Sep 2006
    any pics of your mirrors?
    Quote Originally Posted by R1convert View Post
  6. #6
    Mar 2007
    West Virginia
    I like those mirrors, they are nice and small but out where you can see them.
    That plug is just mild steel, but you're going at it the wrong way. Start off with a small bit, something like 1/16" and drill as deep as you need to go, then work up to a larger bit. You will need to go several steps to get there, but it will drill out easily. Big bits don't do well drilling in solid steel, you need the small bit to create the lead hole.
    Life has no remote control, get up and change it yourself.
  7. #7
    Apr 2006
    Annapolis, Md
    And drill slow with some oil so you don't burn the bit out.
    2013 Mid Atlantic Meet CLICK HERE
  8. #8
    Very Active Member RICKTOR's Avatar
    Mar 2009
    Winnipeg Manitoba Canada
    Those chunks of metal are purposefully put there as a weight to stop handle bar vibration during certain engine RPM. Removing those will make your hands go numb. Looks cool though.
  9. #9
    Mar 2008
    Cobourg,Ontario
    Quote Originally Posted by gasolina View Post
    Here's one
ID:	5882   Click image for larger version.
ID:	5883   Click image for larger version.
  10. #10
    Active Member
    Sep 2006
    Yep, thats what I've been doing, going up one size at a time. It has been working well. It was one of those small bits that I guess I fatigued when it was as deep as possible, and broke off. I tried the step-ed bit after to see if I could get at the broken bit any better.
    I'm wondering if I could drill a second hole, enough for an extractor bit, heat the handlebars with a torch, and twist the plug out... going to give it a try in hopes of saving me the downtime for a new bar.
  11. #11
    Active Member
    Sep 2006
    Hopefully the added weight of the mirrors counteract this, and the grips should help a little too... fingers crossed (when I can feel them )
    Quote Originally Posted by RICKTOR View Post
  12. #12
    Active Member
    Sep 2006
    Nice ride! I can see the R1 influences in your bike. I dig the blacked out look, makes the bike look mean as hell! Thanks for the pics
    Here's one
  13. #13
    Mar 2008
    Cobourg,Ontario
    Thanks enjoying the cruiser thing alot more than i thought i would
  14. #14
    Aug 2007
    Montreal subburb
    Gasolina , you are in a jam ..
    I have had all kinds of trouble doing work
    on cars in the last 30 years , looking at your
    situation , what Iwould do is: take small drill bits
    and drill holes around your broken drillbit ,
    as close as possible to the broken drillbit ,
    may need to drill 8-10 holes (maybe more)
    to weaken the metal around your broken drillbit ,
    Zoom says it is mild steel , so drill slow ,
    the most important part of drilling is going slow and
    pressing hard , you will see the metal come out
    you will know when you are doing it right because
    you will progress fast, drill too fast and your drillbit
    will overheat ,and you will round the end ,then all you
    see is smoke ,your drillbit is no good anymore until
    you resharpen it.
    Once you have surrounded the broken drillbit with
    small holes almost touching each other , try going
    with a drillbit 2 or 3 sizes bigger , and go in the new
    holes ,if you hear "tac tac tac" stop , your new bit
    is touching the broken drillbit ,that can only do more
    damage. with angles (drilling from one hole towards
    the next hole) and gentle twisting you will take
    out as much metal as you can until you can remove the
    broken drillbit , by the time you will get it out , you
    probably will have mastered the art of drilling , so
    you can resume getting the big chunck out to install your
    mirror.
    Good luck .
    DOH ! just noticed this is a 6 days old thread
    probably got it done by now..
  15. #15
    Active Member
    Mar 2012
    Mexico
    Default So far with my mirrors...
    Bought some Kuryakyn bar end mirrors and I got to those steel pieces inside the handlebar. Glad I searched before drilling. I thought they were thin pieces, not solid steel.
    I won't get into that trouble. I don't know why kuryakyn does not advice about this and place them as " direct fit" for the 109. .
    I'll just order the stems and make thed ordinary mirrors.
