RatedR Timing Retard Eliminator (TRE) Install
Results 1 to 16 of 16
Thread: RatedR Timing Retard Eliminator (TRE) Install
    Active Member foobar's Avatar
    Nov 2007
    S. Fla
    Default RatedR Timing Retard Eliminator (TRE) Install
    I have owned my '07 M109 since new-- 0mi. I have been slow to mod it, because it seems like the perfect bike for me, but sure enough, over time, I have been slowly giving in to the mod bug.
    I ordered the Timing Retard Eliminator for the M109/C109 from RatedR w/ the thought of "free hp" from a timing alteration after reading about it on this forum. It is a nice unit w/ the proper connections to make a clean, in-line insertion of the TRE. I was surprised to see a Suzuki logo on the paperwork that came w/ it-- I assume it is either a Suzuki "performance" part or the dealer is too small for Suzuki to go after for using the logo.
    I popped the right side panel off the bike and went to connect it up, and was surprised to find an identical looking unit already installed on the bike-- I mean, it looks exactly the same. I have owned my '9 since new.
    So the questions are:
    - Does the RatedR TRE replace or augment the existing unit on the bike?
    - Did Suzuki start adding an in-line TRE to M109's?
    - Did I waste my money?
    I also have a query into RatedR, but seeing how they are out of AU, I am hoping the forum will provide an answer quicker.
    Very Active Member tanker0027's Avatar
    Jul 2007
    Owasso, OK.
    I also have a new '07 and I have a GiPro. There was nothing installed 'inline' with the gear position switch if that's what you're referring to.
    I'm not sure why anything would be there to begin with Maybe someone will chime in if they've seen something similar.
    This is how my sensor looked before connecting my GiPro(borrowed from JUtah's how-to),
    I think this might be the TRE you have, but I'm not familiar with the RatedR TRE,
    Good times
    Jul 2007
    Owasso, OK.
    Ok, I missed your pic for some reason. That's strange but it sure looks like you have one already installed
  5. #4
    Nov 2007
    S. Fla
    I know the goofy things manufacturers will do in the name of decreasing liability (build a monster engine, then dial back the timing...) An SLP/Diablo tune on my LS1 GTO made a difference. That's why I wanted to put this unit in the '9...
    I probably will do some "trial and error" later today, but I have my kids running around right now. I was hoping for a quick answer.
    I am the only owner of the bike-- "trip 2" matches the odo. The "new" part looks exactly like what is already in there...
    2002 R1150R
    2004 GTO
    2006 K1200R
    2007 M109R
  6. #5
    Nov 2007
    S. Fla
    Quote Originally Posted by tanker0027 View Post
    That would be a better picture of what is both already installed and what I purchased...
    2002 R1150R
    2004 GTO
    2006 K1200R
    2007 M109R
  7. #6
    Apr 2008
    Rochester, NY
    I have also owned my '07 M109 since new,
    and mine didn't come with a free TRE installed.
    And to my knowledge, Suzuki doesn't sell one.
    Either someone at yer dealer performed some unauthorized work on yer bike,
    or.... the bike wasn't exactly "new".
    I think you need to revisit your dealer and have a heart-to-heart talk.
  8. #7
    Very Active Member Tigz's Avatar
    Feb 2009
    Matteson, Il
    since that it seem, you'll have an extra one that you won't be using, why don't you send it my way, lol. I'll check it out and see if I'll make a difference...
  9. #8
    Very Active Member holden,on's Avatar
    Mar 2008
    Quote Originally Posted by da piglet View Post
  10. #9
    Very Active Member Gramps's Avatar
    Sep 2007
    small ranch/farm out in the country 10 miles north of Burlington N.C.
    I think your dealer installed a free TRE for you...maybe he was testing a stock unit to see how it worked and forgot to remove it...maybe someone else bought the bike then backed out and wanted it installed prior to delivery...or maybe the TRE fairy's installed the unit the minute after you signed the papers....either way I see no reason to complain to the dealer...now you have a back-up when or if the other one fails Count your blessings ...sometimes they are hard to find.
  11. #10
    Nov 2007
    S. Fla
    I normally think along those lines, as well. However, a H.S. friend of mine works there... The bike was in the crate before I bought it... Trip2 matches the ODO. The dealer has a good rep in the area. The stars don't align for the used-car dealer conspiracy theory.
    Is this a Suzuki speed part, along the lines of GM Performance Parts (GMPPP) or Ford Racing Perfomance parts (FRPP)?
    2002 R1150R
    2004 GTO
    2006 K1200R
    2007 M109R
  12. #11
    Nov 2007
    S. Fla
    Quote Originally Posted by Tigz View Post
    Sure, PM me and make a fair offer. As you know, it is brand new...
    2002 R1150R
    2004 GTO
    2006 K1200R
    2007 M109R
  13. #12
    Very Active Member prwelder64's Avatar
    Feb 2009
    oglesby texas
    Default pm sent
    intersted on the part give me a price
    arnott air ride, superman covers w/k&n filters, pc III, rainey 5" cannon,280 rear and 160 front with extreme wrenched wheels.
  14. #13
    Nov 2007
    S. Fla
    Default Done looking at it
    I tested both the orig and the RatedR unit w/ an Ohm meter-- not a terribly accurate one though. Both read the same 3k Ohms (supposted to be 2.7k Ohm according to this:
    http://www.m109riders.com/forums/showthread.php?t=97244
    I felt my '9 ran ever so slightly better on the RatedR unit-- not that the bike ran bad on the other. Psycological? Maybe. The new RatedR unit is in my bike. No complaints w/ what RatedR provided.
    I am happy w/ my '9 and have had no problems w/ it except for a mild version of the 1-2 gear crunch everyone has... I am convinced that I have a new-from-the-crate bike.
    > Hi,
    > That is definitely one of my TRE's that someone has added in there.
    > The bike would not have been supplied from Suzuki with anything fitted like
    > that.
    > Cheers,
    > Steve McDowall
    > 0403 029 182
    > WWW.RATEDRPARTS.COM
    Anyone on here work at a dealership or Suzuki? Would there be any reason to have a TRE pre-installed? Was the original put on to smooth the bike out and make it easier to ride? Secret recall? Anything?
    Wierd.
    2002 R1150R
    2004 GTO
    2006 K1200R
    2007 M109R
  15. #14
    Very Active Member BigBadBaz's Avatar
    Oct 2007
    Central Coast NSW - Australia
    Quote Originally Posted by foobar View Post
    Don't get me wrong... TRE's are good things... I have one myself... although the "free hp" or "added hp" is a bit of a misconception IMO... By adding a TRE, you are not giving the bike anymore HP that it already has... All you are doing is applying it differently... Guys who buy this $50 part and expect a nice little HP gain are often disappointed... I think this is why there are mixed reviews on TRE's...
    The TRE for an M109R, does nothing more then send a signal to the OEM ECU to "trick it" so it uses the 4th gear fuel/timing map no matter what gear the bike is in... except when you put the bike in "Neutral" and the TRE turns off till you put the bike back into gear... It does this with about .20c worth of electrical components... 1 X Transistor @ .15c & 2 X Resistors @ .02c each... (Cheaper if you buy in bulk... and that's Aussie cents... so it would be cheaper again in US cents... )
    Nope... You've just bought something you already have installed on ya bike..! Although fitting 2 X TRE's inline might make the bike think it's in 8th gear...
    I highly doubt it... I'd say the dealer popped it in there for some reason and you were not aware of it till now...
    Not if you can sell it to someone else you haven't...
    I'm an Aussie... RatedR import the TRE's from the US... You've just imported one back again... Ya TRE has more miles on it that you will rack up in a few years... and by the look of it... it looks no different then the JSD TRE and I expect this is who RatedR buy them from in the first place and perhaps repack them for sale down here in Oz...
    Cheers from Downunder & Ride Safe...
    BBB
  16. #15
    Very Active Member No Mas's Avatar
    Jul 2008
    kansas City/Lee's summit
    Did your friend set you up to have the fastest stock 109 from that dealer so you could smoke his boss.
  17. #16
    Mar 2007
    West Virginia
    I installed a GiPro on my 07 and it sure didn't have a TRE already on it. I'd say you got lucky and got a free one, though it would be interesting to find why the dealer or factory installed it.
Tags for this Thread
