Hey guys, I have made a few Debeaver brackets for some mates here in Aussie land and thought I could share with you guys.
This is the debeaver diagram I made.
This it what it looks like.
Hopefully this will come to good use :)
Cheers,
Boogs...
Cheers,
Boogs...
thanks!
Edmonton and Alberta Quader's unite!http://www.outlawatvclub.com
I'm having an itch for a trimming party.
Nice job! Looks like it's heavy enough to hold the lights and tag solidly too.
Life has no remote control, get up and change it yourself.
Steel is the go as aluminium will break where you bend it eventually and bits fall off. Stainless steel even better as it doesnt rust. Suggest 1.6 mm thick as being plenty thick enough in either types of steel.
I like, how about some pics of the finished set up?I'm thinking this is the bracket for me.
Very similar to the below pic. The below pic has the very 1st bracket I made and my brackets have changed slightly in design. However, the pic below is pretty much the same end result as the latest bracket in the 1st post.
Cheers,
Boogs...
bump
this is an old post sorry for bumping but since the OP's hosted image of the diagram is gone i'm wondering if someone saved it and can repost it here or send me the diagram.
Thanks.
I just made another one for myself, but didn't take any pics. From what I remember, I started with 2 inch wide aluminum stock. The main body was 7" wide and the tabs were 1.5" each for a total length of 9". The 7" matches my plate bracket width.
Mark down the length of the piece, separating it into 3/4 and 1 1/4 wide areas with a felt tip pen. The 3/4 wide area will be the part that attaches to the 2 bolts coming down from the fender. Drill 2 holes to match these bolts. The tabs will be 1 1/2 long and will be bent at each end 90 degrees from the middle 7" section. Those 2 tabs get a hole each for turnsignal attachment.
The 1 1/4 section will be used to hold the licence plate, and will be bent at a 45 degree angle. It will also be shortened from 9" to 7" by cutting off 1 1/2 at each end of the 1 1/4 wide area.
You should then have a finished plate holder. I spray painted mine black.
Sorry, no pics. I'm sure its clear as mud.
Grey 08 with a few tweaks, lol!...... Let's Ride! Mods: Yes, and Yes, and Yes!
K6, Black, PCV, Spike filters, 2-1 custom exhaust, Pair valves blocked, Secondary butterflies removed, Lowered 2.75", Tacho junked, Indicators replaced and relocated,
Debeavered, 280 rear on Contrast Gasser rims, ISO Grips with Stiletto's, Cycle House Leavers & matching shorty Kickstand, Scythe II Mirrors & Axle Spikes, Nacel Glove Box
Ok found the pics
Hope this helps you out
Cheers,
Boogs
I bought this one for $17.38 and it works perfectly with the stock turn signals and I'm sure with any others as well. The only 'extra' work was drilling two holes to match the bracket (no big deal at all) and I did buy a couple of longer metric hex bolts for the mount.
http://www.mrcycles.com/eshopprod_ca...ct_1096613.htm
Yes, I had read that about the aluminum brackets when I was deciding how I wanted to de-beaver. This one is good hard steel. The license plate may bend, but the bracket won't unless you bend it intentionally. A satisfied customer here. The only drawback was that I did have to drill holes for it and ended up having to drill a hole for the left side turn signal wire to go through to keep it from being pulled too tightly. But wasn't a big deal at all. If I can do it, anyone can. Oh, another thing to mention is that you will need a license plate light or a lighted plate frame. I don't really ride at night so I haven't put one on yet.
Dang man you're 100% correct. I guess I had forgotten that it said aluminum. Also didn't realize aluminum would be so thick. It must be close to 1/8" thick. Seems very sturdy like steel, but perhaps it is lighter. I'd be really surprised if I have any trouble with it, time will tell.
