BARR's Pass Button 2 Garage Door Opener Mod
Page 1 of 2 12 LastLast
Results 1 to 30 of 41
Thread: BARR's Pass Button 2 Garage Door Opener Mod
    Active Member BARRMAN's Avatar
    Jun 2008
    Bradenton, Florida
    Default BARR's Pass Button 2 Garage Door Opener Mod
    Like many others I wanted to install a button for my garage door opener. I intuitively looked at the seldom used Pass button since it is a momentary button just like the garage door opener buttons.
    I started by reading the wiring diagram and found that the pass button was simply paralleled with the brights switch. I dismantled the left side switch module and followed the Pass button wires. I found that they attached to the brights switch wires about 6 inches after leaving the switch module. I disconnected the wiring harness from where it plugged in behind the headlight and pulled the entire harness off the bike. I taped a new set of wires to the end of a hanger and pushed them through the harness tubing. I then cut the pass button wires where they attached to the headlight bright switch wires and taped up the stubs. I stripped and attached the pass button wires to the 2 new wires I just ran through the harness sleeving and reassembled and reinstalled the left side switch module.
    Next I opened up my garage door module, soldered a couple of wires to the momentary button connections on the bottom of the circuit board and ran them out the side the garage door opener case. The original switch is still functional since I'm just paralleling the connections. I attached those 2 wires to the wires that I ran to the pass button and tested my Pass button garage door opener.....sweet!
    I just tie wrapped everything in place and reassembled the headlight cover and job complete.
ID:	623   Click image for larger version.
ID:	624   Click image for larger version.
ID:	625   Click image for larger version.
    Very Active Member Ranchhand's Avatar
    May 2008
    Good idea No garage door but I wonder if that will work with an electric gate opener
    2007 M109R LE-Sideburner-Suzuki sport windsheild- gel seats-billet Suzuki swivel backrest-250 E3-polish/painted derby cover- polished/painted rims- painted rotors- custom speedo plate- blue LED's- homemade debeaver w/LED plate mount- debadged- drilled/polished risers- polished windshield hardware- lowered 2 3/4
    Very Active Member COLORYDER's Avatar
    Oct 2007
    Colorado Springs CO
    I would imagine that it would work with pretty much any device of that nature.
  5. #4
    Very Active Member muskrat's Avatar
    Mar 2008
    Joliet, IL
    ... i had done this on my previous bike. glad to see how it was done on the 9, added to the winter mod list.
    It's better to be judged by twelve than carried by six.
  6. #5
    Very Active Member halfdome109r's Avatar
    Jun 2008
    San Jose CA.
    Quote Originally Posted by Ranchhand View Post
    yes it would, same concept.
    Life is too short, live it your way.
  7. #6
    Very Active Member 07red109david's Avatar
    Aug 2008
    Westport Ma
    I use that pass button for the corners at night alll the time..I would just put a button on the bike...Just my thought...
ID:	1952   Click image for larger version.
ID:	1953   Click image for larger version.
  8. #7
    Very Active Member Moonbaby's Avatar
    Jul 2006
    Newnan, GA (Southwest of Atlanta)
    I thought about using the pass switch for the garage door as well... I actually had it all apart and was cut and soldiered everything until I realized how much I actually use it at night.
    I installed a small button on the bottom back of right side cover. You can not even tell it is there. I also used a 1/8" stero plug on the garage door opener so i could take it off easily and use it anywhere else... if anyone is interested I will take pics....
  9. #8
    Nov 2008
    West Valley City, Utah
    Quote Originally Posted by Moonbaby View Post
    I'd like to see how you did that. Sounds like it might be a nice way to do it
  10. #9
    Very Active Member F OPEC's Avatar
    Jun 2008
    Fort Mill, SC
    Quote Originally Posted by 07red109david View Post
    I'm surprised to hear that people are using that button at night. I ride with my high beams on both day and night, at day for visibility and at night so I have enough time to brake after seeing an obstacle. Way too easy to outrun your low beams at night in my opinion! I have the flash 2 pass opener on mine and it works great. Pretty much the same set up as what you did without the soldering. Great Mod!
    07 LE Debadged, Debeavered, Baron's Stealth Plate Bracket, Clear Alternatives Tail Light ,HID Light, Stebel Air Horn, Engine Case Guards
  11. #10
    Jun 2008
    Bradenton, Florida
    I was recently cut off 3 times in one day and found myself thinking of another useful mod and function for that button....I suspect this one may prove to have some therapeutic benefits as well
  12. #11
    Jun 2008
    Fort Mill, SC
    Quote Originally Posted by BARRMAN View Post
    I'm all about taking out those evil minivans!!!!
  13. #12
    Very Active Member Swede's Avatar
    Apr 2006
    Antioch Ca
    Great mod. Looks something like what I want to do. I never use it anyway. I always run with my brights on at any time of the day. Makes sure everyone can see me and that I can see well in front of me.
  14. #13
    Active Member Farmer's Avatar
    Apr 2008
    Scottsboro, AL
    i done the same mod as well last year. i mounted mine in the same place and used gasket sealant around the edges of the garage opener to keep moisture out. i liked using the pass button because i didnt want to drill holes in anything or mount a button for it.
    if it won't fit, FORCE IT!
  15. #14
    Very Active Member jrrose69's Avatar
    Jul 2008
    Brandon, South Dakota
    I did my garage door opener mod but the system I used was under 40 bucks. I do not have any pic to show you. I did have to drill a hole for the remote button on the bottom side of my left side panel. the button is tiny not quite the size of a pencil eraser it works well and was a cheep mod. it took me about 15, 20 mins to do!!
  16. #15
    Very Active Member athomas387's Avatar
    Nov 2008
    North Atlanta
    cool beans
    40 degrees and partially sunny, i'm probably out riding
  17. #16
    Very Active Member HyperPete's Avatar
    May 2008
    Lancaster County, Pennsylvania
    Barrman, do you have a url for that mod?!
    Some scientists claim that hydrogen, because it is so plentiful, is the basic building block of the universe. I dispute that. I say there is more stupidity than hydrogen, and that is the basic building block of the universe. Frank Zappa
  18. #17
    Very Active Member windycityrider's Avatar
    Jul 2007
    Chicagoland
    Quote Originally Posted by HyperPete View Post
    check out this link to "flash 2 pass". easier install imho.
    http://rds.yahoo.com/_ylt=A0geu.QEig...hnologies.com/
    OFTEN IMITATED BUT NEVER DUPLICATED.......THE
    WINDY CITY IS MY PLAYGROUND
  19. #18
    Jun 2008
    Bradenton, Florida
    No URL, only the pics I posted.
    The toughest part for me was dismantling and reassembling the switch module but since I have already found and have shown you the wires you need, you don't need to disassemble that module at all. You just remove the whole switch assembly and wire harness from headlight cover. Cut the wire harness tubing back to expose the pass wires and insert your 2 new wires into the wire harness then attach to the garage door opener and pass wires as shown.
    Good luck, it is a sweet and convenient mod that costs nothing
    ...Oh and the mini gun upgrade instructions are in process.
    06 burple - custom debeaver, kuryakyn ISO grips, stiletto ends, chrome rear brake cover, wrap around rear LED lights under cowl, kuryakyn run/turn/brake module, rear mini bullet signals, drilled baffles, cobra bungee knobs, 6K HID, suzuki tank bra, smoked taillight, blazer driving lights, 12v adapter, drag specialties teardrop mirrors, custom speedo faceplate, blue gauges, tach relocation, kuryakyn chrome drink holder, customized air filter box with blue LEDs.
  20. #19
    May 2008
    It's the mini-gun mod I was talking about.
    I already have a flash to pass module installed that does not change the button function.
    (It was $29)
  21. #20
    Active Member pedro66's Avatar
    Mar 2009
    Bartow FL
    Buy a module called a TR7 from eBay about $20 set it to read pulses and set it for 3 pulses. connect the output to you door opener and input to the high beam
    When you use pass button for 3 flashes it opens the door
  22. #21
    Very Active Member Baker's Avatar
    Dec 2008
    Tomball, Tx
    Thumbs up
    Here is another alternative that I used. It's $29.95 and easy to install. I put the entire install in the headlamp nacelle with a mini garage door opener.....You want the AS5PG2.
    The web address is www.autoswitch.com
  23. #22
    Mar 2009
    Quote Originally Posted by pedro66 View Post
    would any 3 flashes from a car or bike open the door? does it have security feature?
  24. #23
    Mar 2009
    Bartow FL
    Quote Originally Posted by Djxtrodinaire View Post
    Its has to be 3 flashes from your bike within 5 seconds for the module to read the electrical pulses and send them to your garage remote. it has nothing to do with the flashes as such you dont even have to have a headlight bulb as your just reading the signal to the light
  25. #24
    Very Active Member scottr63's Avatar
    Sep 2006
    D'Iberville, MS.
    Default mod
    I put my opener in my pocket. When I get home I press it. Then if I need it, I can use it in my Tacoma. No mods needed
    Cobra Dragsters Long DeBaffled Chromed front and rear rims Chrome covered lower fork/front calibers Chrome covered rear caliper Chrome coverd Drive shaft Chrome covered swing arm Kuryakyn Flame Grips and Foot Boards Arlen Ness Mirrors Carbon Fiber Fuel Tank Bra LED Tail Light ATRE Gear Emulator Dual Spiked Air Cleaner Intake Filters Billet Backrest m109 Fender Eliminator Bracket Plate Mount Fi2000R Processor Speedometer and Tach cover plates
  26. #25
    Very Active Member Duende01's Avatar
    May 2009
    Clarksville, Tennessee
    Quote Originally Posted by scottr63 View Post
    I do the same and have never had an issue. BTW, talk about a worthless thread revival
    -2008 M109R "The Silver Bullet"
    -2013 HD Road King "The Orange Crush"
    -2015 HD Sportster Iron "TBD"
  27. #26
    Very Active Member MarlboroLts's Avatar
    Sep 2008
    San Antonio, TX
    i just did the same mod, slightly different. Grabbed a Genie Universal remote from Lowe's. Soldered two wires to the switch circuit board, sealed it all up with black silicone, and velcroed it inside the right-side painted panel, behind the rear jug. Just below that is the switch I installed for the Pro-Cycle Tach a few years back. I don't use the record feature anymore, so I wired that switch to the remote. Works great.
  28. #27
    Very Active Member Paladin's Avatar
    Mar 2011
    Idaho
    Quote Originally Posted by MarlboroLts View Post
    Very good idea M,LTS. Neat idea and install, remotes are cheap so why not mount it rather then carry it.
    Political language... is designed to make lies sound truthful and murder respectable, and to give an appearance of solidity to pure wind.
    George Orwell
  29. #28
    Sep 2008
    San Antonio, TX
    Quote Originally Posted by BigM109r2 View Post
    Exactly. Just hit the button as I'm comin' up the street.
  30. #29
    Very Active Member Luvs2Play's Avatar
    Dec 2012
    Nebraska
    I call this the winner!
  31. #30
    Very Active Member Tigz's Avatar
    Feb 2009
    Matteson, Il
    Did the same thing back in 2009....relocated this spring with my air ride controls.
    sent from Tigz Galaxy
