Back Off Brake Light Flasher Install
Results 1 to 11 of 11
Thread: Back Off Brake Light Flasher Install
    Default Back Off Brake Light Flasher Install
    Hi all! I just finished installing a Back Off XP brake light flasher module and thought I'd post a couple pictures of a quick and easy install location.
    As usual, I made more work out of the install than it should have been! I was originally going to mount the module tucked up on top of the rear wheel well somewhere, so I took off the Corbin hard bag on one side and took apart a bunch of stuff that I didn't need to, so if you mount yours where the pictures show, all you really have to take off is the seat. I did have to trim the battery cover so that it would not interfear with the Back Off module, but that is very easy to do.
    Unplug the brake light/tail light/turn signal plug, located on the left side rear of the battery case behind the cross brace, and use a test light to determin which wire is the brake light. Then just snip that wire and tie the module in as directed. Very simple. I suggest soldering the connections together if you can. Mount the module with the supplied two-sided tape, and your done!
    Very Active Member Aussie109r's Avatar
    Dec 2007
    Rutherford NSW Aus
    Default Re: Back Off Brake Light Flasher Install
    Well done EZ mate, good spot, I'm yet to put mine on, may have a look at that location......
    2008 M109r Black Mods: H.I.D light, Scala rider bluetooth,Tank bra..Radiator Guard  The BBB TRE Mk1, soon when i get around to it....Stebel horn, Back-off XP,Grips with acc......BILL
    Very Active Member Rick REAPER Grimm's Avatar
    Jan 2008
    Elgin, IL
    I really like your install. I did mine the hard way about a month ago and put it back by the saddle bag rail. Either way,the Back Off modulator works great.
    Reaper
    Combat Veterans Motorcycle Association
    http://combatvet.org
    Active Member doraiders's Avatar
    Jun 2008
    RANCHO CASCADE,CA
    Default backoff install
    hey bro what happen to your pics,i was able to view them on the old site
    Very Active Member Phat Bak's Avatar
    Sep 2008
    Clinton, MD
    Very Active Member BirdMan's Avatar
    May 2007
    Chesapeake VA.
    Default correct wires???????
    I just got this mod and want to know for sure what wires to cut .. looks easy but want to make it a quick mod as i think its a great bonus to have as people are not looking for sure thanks for the help
    Ken(BirdMan)
    Very Active Member AWESOME109's Avatar
    Jan 2007
    San Diego
    Here you go. Only one wire to cut. It is white with a black stripe.
    Mode 1: 3 short flashes then 1 long, then it repeats.
    Mode 2: 5 short flashes, then steady on.
    Sep 2008
    bump
    Very Active Member 5111's Avatar
    Apr 2007
    Arlington, TX
    Did you have to extend your wires any to make it work in this location? I don't see how you can easily make the connections without extending the wires. Did you go before or after the plug?
    2008 Suzuki M109R LE
    Very Active Member crossq's Avatar
    Aug 2009
    Pearland/Houston Tx
    Default XP install
    Quote Originally Posted by AWESOME109 View Post
    Thanks, Big Thumbs Up to AWSOME9...!!!!! .
    crossq
    Active Member
    May 2006
    Thumbs up
    I used this this evening to install my "back off" this evening. Just what I needed. Thx.
