Results 1 to 22 of 22
Thread: Frt Tire/fender
    Very Active Member SilverFox's Avatar
    May 2012
    Daphne, Alabama
    Default Frt Tire/fender
    I currently run a 130/18 on the front.. I tried to run the 160 w/stock fender and it rubbed... what is the 2006 stock fender clearance? What I am attempting to see is if there is more clearance between the Stealth fender and a 130... Will a 150 or 160 even fit without extenders?
    Thanks in advance...
    Jim
    Oklahoma
    Quote Originally Posted by SilverFox View Post
    Jim
    Supposedly the Low & Mean Stealth ( I thought is was called The Reaper) front fender was designed to be used with a 160 front. I have and will always have a 130 up front, do not like big front tires. I would prefer to put a 100 up front, like a HD Night Train. But then I would have to change the front fender, and I like my Reaper front fender too much to want to change it out for something different.
    Sent from my Super Duper Cool Anus using Tapatoot!
    2006 M109R. Corbin Smuggler, Low & Mean chrome chin scoop and Reeper front fender, Cobra Tri-Pro exhaust, Big Air intakes, D2Moto tail light, Kuryakin clear signals.
    Apr 2011
    Pennsauken, New Jersey
    Jim
    Jim I have my stock fender over my 160 for this whole riding season. It is close and I haven't had any problems with it. I still am going to put the fender extenders that are sitting in the garage on. It's just not worth the risk of damaging your fender stock or aftermarket and the cost to have it fixed/repainted when you can get the extenders for $60.00 and have no worries.
    Very Active Member biscuitpimp's Avatar
    soddy daisy, tn
    I run the 160 up front with no issues. Yeah, it's a little close when the tire is new but unless you ride on gravel roads alot it shouldn't be an issue.
    she s not quite stock.
    Very Active Member BAD BOY M109R's Avatar
    Harwood Mo. (SW)
    Mine never rubbed did you loosen the bolts and push the fender up all the way and tighten it up... I made extentions cheap and easy. only because I live on a gravel road and that tire picks up gravel and it was going to break the rear of the fender...
    BONE STOCK
    I have the 160 on mine and ran it for maybe 2 weeks without extenders. It picked up a few gravels and ran them around the fender during that time and I was afraid sooner or later it would pick up a bigger one, so I made extenders for it.
    I think they look cooler with the fender hugging the tire but I didn't want to risk damaging it.
    Very Active Member dcstang67's Avatar
    Southern MA
    I just put the stealth on mine with a 160 metz. The stealth is made to clear the 160 with no extenders. There is about a 1/4" gap with the 160. Before i put the stealth on, I had extenders on the stock fender. I made my own out of aluminum bar and stainless nuts and bolts. The lift the fender about 1/2" over stock location.
    07 M109r LE Copperhead paint * 260/160 * Cobra Swept Exhaust* Corbin seat * Tach relocated * Debeavered * Braided lines & cables * Rivco Risers * Big Air * Much, Much More!
    Very Active Member LOFLYR's Avatar
    Mar 2012
    Boise, ID
    Yep, the low and mean fender is designed for a 160 tire. Hugs close at the top but there is plenty of room between fender and tire at the bottom. I would not run extenders with the low and mean fender, would pull it too far away at the top and it wouldn't look as good. I work off a dirt/gravel road and heard rocks hitting the stock fender with the 160, no problems with the L&M.
    2007 M109R Pearl White - Mods: Gutted/Debaffled Exhaust, Yana Shiki 2" Bones, TDE TRE, V-Stream Windshield, Debadged, Debeavered, Kury Rear Tails, Tach Relocated, Kury ISO Grips, Kury Transformer Throttle Boss, Baron Bullet Bar Ends, Kury Switchblade Pegs, Cyclehouse Levers, Boulevard Mirrors, Rivco Highway Pegs, Corbin Seat, Metz 240/160. ​RIP
    Very Active Member RUBZERK's Avatar
    Lancaster, PA.
    this could happen
    "You cant argue with my 9mm..........well you can, but you'll end up bleeding alot"
    RUBZERK = Are You BZERK
    Very Active Member gmooney72's Avatar
    Mar 2012
    NYC
    I'm running a Dunlop D251 150/60VR/18 , its a bit pricy but I'm sure it will not rub or no stones or gravel will damage front fender and it is also a true front tire.
    Suzuki Engine Guard,Chrome Levers,Master Cylinder,Clucth Perch,Housings from Chip.Black ISO Grips,Accent Rings,Stilleto ends,Throttle Boss, Kury LED Lights.Joe's of Fla.180 LED Kit,JT's Knight Strip .Speedo/Tach from Webslinger.Carbon Fiber Kit,and tank cover.HID Headlight.Debeavered w Raw LED Strip,Chrome license plate w LED.OEM Chrome Drive shaft and Swing arm covers.Taillight painted by Brad Short OEM Pipes.VSport Shield,Scithe Mirrors
    Very Active Member BigBully's Avatar
    Woodbridge, Va
    Quote Originally Posted by RUBZERK View Post
    this could happen
    Running through rocks?
    High air pressure? What air pressure did you run?
    High speed runs or just cruising?
    2011 Black, Cobra PowerPro, Debeavered, DeReflectored, LED Licence plate light, 280 Metzeler Rear/160 Metzeler Front, Legacy Wheels, Sportiva HID Headlight, 2.25 Lowering Bones, Chrome Grill, Chrome Motor Mirror Plates
    Lancaster, PA.
    thats not mine. i run extenders
    Very Active Member Giddyup109's Avatar
    Maryland
    Been running my 160 with a stock fender for years now. I bought bolts with a much smaller head than the stock one and then used stainless washers. I pulled the fender up as high as it could go before tightening and no rubbing issues.
    Sent from a Thunderbolt
    "Blaze"
    Woodbridge, Va
    Quote Originally Posted by Giddyup109 View Post
    Pictures?
    Maryland
    Quote Originally Posted by BigBully View Post
    Pictures?
    Is this your way of asking me if I would be so kind as to go and snap some pictures of my ingenious set up? Complete sentences go a long way when making requests......
    "Blaze"
    Woodbridge, Va
    My apologies. Fellow rider Giddyup109, if you have the time out of what I'm sure is a busy schedule, could you please enlighten me and also other inquisitive fellow riders as to how you overcame this issue with a minute pictograph session. We would be highly greatful. Thank you.
    Very Active Member Blackey's Avatar
    Seattle
    Well crafted sentence! Perhaps bonus pictures should be awarded?
    09 "Blackey" - Swept, Engine Case Guarded, Derby'd, Iso Gripped, Badged, Boned, De-Shuddered, Beavered, Risen, Cabled
    Mar 2012
    Boise, ID
    Haha you have to do it now Giddy!
    Just in case Giddy is indeed too busy...
    If you take out on the bolts for the fender you will see there is a larger section of the bolt just past the head that fits inside the fender and holds it in place. This is what prevents you from pulling the fender up. If you were to get regular bolts and use a washer to fill the space you would gain 1/8 to 1/4 of an inch.
    All that said I ran a 160 with stock fender and stock bolts and I work down a dirt road, didn't have a problem.
    Maryland
    Touche sir....Touche! I will get some pics up today for you forum scholar, with a request like that how could I not?
    "Blaze"
    Woodbridge, Va
    Thanks, I appreciate it. Thanks for taking it all in for good fun.
    Very Active Member Bujee1's Avatar
    Los Angeles, Ca
    Funny thread!
    I've had the 160 for 13,000 miles now without issues. I loosed the bolts, wedged a screw driver between the tire and fender and then retightened them. Like I said, no issues. Ride safe.
    2008 Candy Max Orange,Chrome wheels, Debadged,poorman's debeaver,Garmin 765T GPS, V-Stream Touring windshield, Corbin Seat, OEM Engine guards,Metz 160/60 front 260/40 rear,Chrome Stebel air horn, Jardine QD Luggage rack and backrest,Orange LEDs
    By bujee1 at 2010-07-07
