Originally Posted by
Zoom
Are you talking about the small piece that is attached on top of the larger heat shield? They are tack welded to the main shields and are hard to get off without damaging them or the pipe they are attached to. I removed the smaller one on the lower shield on one of my home made exhaust systems and drilled the weld out from inside the pipe. I needed to shorten the shield and the smaller shield on top was in the way. The rear tack weld was cut off and I just used a short chrome bolt in the hole left from the front weld.
