Ok.. First off I want to thank Fishrocks17for coming down, taking time away from his day and letting us borrow his 9 to install the bars and fix any mistakes we might of had..
1. Well bars installed nice and easy.. We need to take off about 0.25" so center clamp can sit better.. It did bolt on but a little snug.
2. Where we made the the cut outs to do the internal wiring for the switch housing had to be moved over 0.25" as well
3. We are able to add more material to the crush tube to show off more. Which is GOOD. It will look even better now. We will add 0.75" to each side.
Other than that everything was good. As you can see from the pictures they look great on the 9 and will look even better once they are chrome or powedercoated. Its still a little hard to tell from the pictures on the top few.. but they are flat they have that stealth look.. They are very different bottom line. If you want to ask Fishrocks17 for his personal opinion, you may do so. But you will not be disappointed with the design and work put into these bars. They are made to stock specs, but can be made to whatever bull back you want.
Suggested MSRP $299.00 - Chrome or Powdercoat
Suggested MSRP $275.00 - Raw Finish.
Can be Purchased through DLP
Will be ready for Purchase Sept.4th
NOW TAKING PRE-ORDERS.
Good job officer. Thank god for your Hypercontrolling ways. Well done.
