Page 1 of 3 123 LastLast
Results 1 to 30 of 66
Thread: How to install Hydraulic clutch
    Very Active Member Rainey5230's Avatar
    Sep 2007
    Taiwan
    Default How to install Hydraulic clutch
    Remove engine side cover and loosen cable nuts , 12mm
    loosen bracket bolt 10mm
    uninstall clutch cable and make wire for it
    pull the old clutch cable make wire follow it
    Then hook new oil hose up
    if you use riser extension under 2"
    Please don't follow old way, Don't cross the motor mount
    by-pass it and go the engine case bottom
    Our oil hose is 155cm , it can fit stock length and 1" riser extension
    ATT this holder , cross it.
    make sure this posittion
    remove the bar end chrome cover and uninstall grip with glass clearner
    remove 2 bottom bolts
    ready to remove stock lever with mount
    this is new lever use bolt , add butter oil
    install lever with master cylinder
    Don't forget put the brass ball in it
    insert the bolt in lever
    tighten the 10mm nut
    and install the lever switch(ignition)
    install the master cylinder in handle bar
    fit the old position
    the bar bottom have a hole, this is switch assy check point.
    install the grip back
    install the bolt and washers with oil hose connector
    tighten them 13mm and 14mm tools
    remove the swingarm bolt 10mm
    maybe you have to use hammer to push the swingarm out.
    check the swingarm head to fit slave cylinder head
    make sure swingarm could be swing very smooth
    remove the shaft swingarm 10mm bolt and make a sign for it.
    when you install it back use, you can setting in correct position.
    remove it
    remove those 2 bolts , 8mm
    you got install slave bracket it back in 10 mins.
    because the oil will be leaking
    when you install swingarm back, it have a check point.
    you must make it in correct position.
    This is hard to install it back, you need screwdriver help you for it.
    then pull the spring to hook swingarm.
    tighten the slave cylinder top nuts 13mm
    How to drain air out hydrualic, Please follow the user manual or ask other member.
    use the compressior can be help you easy install and save a lot time.
    This is a small "star" winch for drining air.
    after all air is drained, tighten it and use water clean this part
    use the cable tie for oil hose position.
    Don't let the shaft linker hit it.
    tighten the bolt 8mm back and mounting the cable in old location.
    inspect all detail and make sure all bolts and nuts tighted
    You can try this way for make your handle bar more clean
    pull the harness switch connector pins out
    there are 2 pins from stock harness side
    New switch have 3 pins jump the middle
    only use front and rear
    finished
    use the 3M BUTYL WINDSCREEN SEALANT for waterproof
    Check it working then install side cover back
    http://www.youtube.com/my_videos_annotate?v=0HOxsFfaSxo
    Very Active Member freddo62's Avatar
    Sep 2009
    france
    very nice RAINEY!!!
    Sep 2007
    Taiwan
    Quote Originally Posted by freddo62 View Post
    very nice RAINEY!!!
    Sorry My english bad if buddy have any questions . Please ask old members.
    Original size pics
    Annapolis, Md
    I would dremel this and not pry it. I state this from experience, as the part is cast. But a very nice right up.
    2013 Mid Atlantic Meet CLICK HERE
    Sep 2007
    Taiwan
    yeah but this steel is soft not really hard.Rasp it will be better.
    I mod 6 bikes here. some 9R is easy to install but some bikes need tuning it.
    Very Active Member BigpapaM109's Avatar
    Oct 2010
    Germantown, MD
    I have pryed everyone I have ever done with no issues. Just have to do a little at a time.
    Very Active Member rudeboy109's Avatar
    Aug 2009
    Los Alamitos in Orange County, So. Cal "The O C"
    Great write up, only one thing left out......buying the Hydraulic clutch... when, where, how much, ect.
    08,M109R2[250 Dunnie, PC3, stebel air horn, K&Ns, flame mirrors, debaged, gutted pipes, suzuki engine guards, piaa hyperwhite headlight, back off modulator, gipro atre, front motor mounts, debeavered, Kuryakyn Iso Grips, Factory Pro star kit, G-Man shifter bushing, Guardian Bell, Catch can mod....... more to come
    Very Active Member WhiteStar's Avatar
    Sep 2008
    So Cal, Inland Empire
    ... definitely interested
    Quote Originally Posted by rudeboy109 View Post
    "Don't worry about it rider"
    That one Man is the secret theme of the entire revelation of God to man through that which is known as the HOLY BIBLE... JESUS CHRIST.
    Very Active Member The HUFF's Avatar
    Morgantown, WV
    Amazing work as usual Rainey!
    The trouble with our liberal friends is not that they are ignorant. It's just that they know so much that isn't so. -- Ronald Reagan
    With Individual Freedom and Individual Salvation comes Individual Accountability. It brings a rewarding life to all. <--The Huff
    Sep 2007
    Taiwan
    ASSY have 2 kind
    one is fit stock length to 1" riser extension.
    http://cgi.ebay.com/ws/eBayISAPI.dll...ht_1060wt_1054
    2" - 3"
    http://cgi.ebay.com/ws/eBayISAPI.dll...ht_1082wt_1054
    Sep 2008
    Quote Originally Posted by Rainey5230 View Post
    ASSY have 2 kind
    2" - 3"
    So it's $199.00 for just the cylinder. We would have to order the these three parts.
    Cutch Mater Cylinder ASSY: 59800-10F20
    Clutch Lever ASSY: 57500-10F10
    SWITCH ASSY: 57560-10F00
    Is that correct?
    Sep 2007
    Taiwan
    Quote Originally Posted by REDSTORM View Post
    Is that correct?
    Yes. Correct.
    Our Slave Cylinder Assy including Cylinder/Oil hose(Italy made)/bracket/bolt with washers.
    Sep 2007
    Taiwan
    ATT: This Suzuki C90 master cylinder painted is same with VZR1800 '09-On brake master cylinder.
    If your bike is 06-08 , the paint color is a little different with right side brake master cylinder.
    but Their master cylinder cap is same. you can order M109R master chrome cap exhchange it.
    Very Active Member Deester's Avatar
    Jun 2010
    Amsterdam, Netherlands
    Do the custom levers fit on the left side? Nice idea though!
    PA
    What is the switch assembly for?
    I thought that was for the brake light
    ya would'nt need that on clutch side
    would ya
    Very Active Member erbemone's Avatar
    Jun 2009
    Tucson, AZ
    Safety switch for starting. Pull clutch in, start bike.
    Sep 2007
    Taiwan
    Quote Originally Posted by Deester View Post
    Hi
    Only one way is search suzuki C90 ('08 model year) custom lever.
    C90 left and right side lever can be install in this case.
    PA
    Quote Originally Posted by erbemone View Post
    Whoops forgot about that must of been brain dead yesterday.
    thanks man............
    Very Active Member Nashty's Avatar
    Manassas, VA.
    What is total cost for everything required as listed below? Can we order everything from you?
    Cutch Mater Cylinder ASSY: 59800-10F20 cost?
    Clutch Lever ASSY: 57500-10F10 cost?
    SWITCH ASSY: 57560-10F00 cost?
    06 Black 9\De-Badged\De-Beavered\Kuryakyn ISO Grips\GI-Pro\Stebel Air-horn\Shift Kit-EVO-S93\Motolights\Kriss Industries Headlight Modulator\Kriss Industries BLT (Break Light\Turn-Signal Flasher)\Kuryakyn Dually ISO Pegs\KewlMetal 2" Chrome Hole Risers\Cycle House Levers and Kickstand\Suzuki Engine Guards\SS-Brake-Throttle Cables\K&N Filters\Cobra Swept Exhaust\Thunder Monster Baffles\Stock Chrome Wheels\Front Gaffler Rotors\Kuryakyn 2320s wLED bulbs\Cobra PowrPro\
    Sep 2007
    Taiwan
    Quote Originally Posted by Nashty View Post
    I bought those 3 item is same with everybody from US. and I don't have any discount.
    those 3 item cost about USD220.0 , but after add international shipping then return to US.
    The cost is too high. My location is in Taiwan.
    Very Active Member bryan67's Avatar
    Salem,WI
    Default will do soon
    just waiting for my Rivco risers and tach. relocator kit. Will add this kit to my wish list for later this summer. have to work a few OT days to get the funds But will Definitly be ordering the kit for 2-3 riser soon. Real nice How to also. Great job Rainey!!!!!!!!!
    Sep 2007
    Taiwan
  23. #23
    I'll just take this set up please. Thank you
  24. #24
    CT
    Has anyone tried this besides Rainey....thoughts...feedback?
  25. #25
    Very Active Member lostrider's Avatar
    Long Island NY
    Quote Originally Posted by peregrine View Post
    Dizzy spell has it installed dave.
    http://www.m109riders.com/forums/sho...=140875&page=4
  26. #26
    Nice video Rainy, this is definitely on my mods to do list, thanks for posting. Can I also make a few suggestions that may help in the future. First by good practice it is recommend to cover the paint when working with brake fluid. A little inadvertent drop will ruin your day pretty quickly on this paint! And when pulling the cable you should pull from the top down so that you don't scuff the show finish of the upper exposed portion of the cable/hose. Just thinking out loud I guess
  27. #27
    CT
    Quote Originally Posted by lostrider View Post
    Thanks, I will look into this when mine gets older.
  28. #28
    Sep 2007
    Taiwan
    Default RE-Design rod connector
    We re-design the slave cylinder rod connector.
    Then you don't need remove release arm when you install this kit.
    After you finished all upper staff(master cylinder , lever ,switch, Please check this post history)
    We suggest go to motorcycle shop that doing this kit install.
    1.
    Check the cable and slave cylinder best angle.
    Then Tighten hydraulic cable connector
    2.Drain air out
    3.Use the wrench turn the release arm down and install the pin to connector.
    PS. This space is very small. You may need other people help you keep turn the wrench.
    4.Tighten the bracket bolts
    5.Install clip R pin.
    6.Push down release arm by hand and adjust slave cylinder position(up or down).
    7. Drain air again and tighten all bolts. Then use water clean all you did.
    8.After check slave cylinder is vertical then use cable tie clamp hydraulic cable on frame.
  29. #29
    Sep 2009
    france
ID:	76719I have the first model, do you sell the modified part only??
  30. #30
    Very Active Member RUBZERK's Avatar
    Lancaster, PA.
    Angry
    just finished installing mine but now i have a problem.
    after i bleed the system my lever will not compress. the shaft on the slave cylinder stays in. if i open the bleeder screw the lever will compress and the slave shaft will release. once i tighten the bleeder screw i am able to compress the lever once but then it will not compress again and the slave shaft stays in.
    what am i doing wrong ?
    "You cant argue with my 9mm..........well you can, but you'll end up bleeding alot"
    BUILT, NOT BOUGHT RUBZERK = Are You BZERK
