Originally Posted by
Canuk
Hey Guy,
I can assure you, the vibration around 3500 rpm, may be exaggerated by worn out motor mounts, but the mounts are not the cause or fix. It is the clutch basket.
You will find that out, once you replace your motor mounts. It might run smoother after you install them, (mine didn't), but the vibration won't go away, until you deal with that clutch basket.
Drop me a line if you have questions, or need help. I don't live too far from you, and I've torn mine down many times.
